Clutch/tranny
Old Jan 16, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
Clutch/tranny
i have a 02 civic auto manual swap.
everytime i press the clutch all the way i hear a weird noise...is it the throw out bearing? Is it ok to drive for now? what will happen if i dont fix it?
thanks
Old Jan 16, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Clutch/tranny
What kind of noise do you hear? Does the sound only happen with the engine running?
Old Jan 16, 2010
Re: Clutch/tranny
like a sisk or something. like air leaking. yes only with the engine running.
shifts fine
Old Jan 16, 2010
RonJ's Avatar
Re: Clutch/tranny
If you only hear the noise when the clutch pedal is held down, then the throw out bearing is a prime suspect, as you already mentioned.
Old Jan 16, 2010
Re: Clutch/tranny
can i drove it still?
Old Jan 16, 2010
RonJ's Avatar
Re: Clutch/tranny
You should fix it as the clutch will likely soon fail.
mattscivicex
Mar 19, 2013 08:41 AM
AznSaint
Dec 10, 2006 08:54 PM
