car is lagging out of every gear... what's wrong?
Old Nov 21, 2006
AznSaint's Avatar
AznSaint is an unknown quantity at this point
my car is lagging out of every gear, no power whatsoever...... it takes like 7seconds for me to generate enough speed to get out of first gear and into second.
i think my clutch is worn out... but im not 100% sure. anybody had this problem yet??
what else could be the problem.... what do i need to change?
i just changed my spark plugs recently.. but i dont think that's the problem.
if i change the clutch.. does that mean i need a new tranny?
my car is at 145k now.... still have the stock clutch/tranny
Old Nov 22, 2006
BoSS's Avatar
BoSS is an unknown quantity at this point
I got 270K and I still have my original clutch and its still holding strong...at least I think it is.
Old Nov 22, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
wow, 270k ? nice
it might be the clutch, do you beat on it a little bit? or do you ride your clutch often? you dont need to replace your entire tranny to change the clutch.
Old Nov 22, 2006
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
165,000 km and my clutch is fine too should I change my spark plugs???
Old Nov 22, 2006
astrosi's Avatar
astrosi is an unknown quantity at this point
2oo2 si 176km clutch still running strong... only major thing was timing belt, tune up, head gasket..
Old Nov 22, 2006
Blkcivic's Avatar
Automatic?
Old Nov 23, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
are you throwing codes? Maybe Ignition coils?
Old Nov 23, 2006
AznSaint's Avatar
brought it to a shop.. they said it was my clutch. so now im going performance clutch and flywheel..... i just said wth... give me the whole package o_O .... didnt want to machine the stock flywheel if a new performance flywheel would cost me another 100 or so...
was driving yesterday and my car started to lose ALL POWER on the dvp... so i pull off the on york mills exit and then NO POWER WHATSOEVER...... my clutch gave out totally..... had to tow it to the shop yesterday and now it's sitting there till tomorrow.
as for the spark plugs... honda recommends you change it every 140k or so according to the manual.. but you should/could change it at 48k or so...
my car is standard....
what do you guys mean by riding the clutch or beat it on a little bit?
thanks
Old Nov 23, 2006
AznSaint's Avatar
are you saying that other possibility problems could be my timing belt? head gasket? even though the shop said it's the clutch... i could get them to check those too if those could be a problem at 140k........
Old Nov 23, 2006
AznSaint's Avatar
ignition coils? wouldn't that relate to not being able to start the car? and throwing codes?
Old Nov 23, 2006
lumina5201's Avatar
lumina5201 is an unknown quantity at this point
riding the clutch is when u keep it depressed at red lights or use it to hold the car when ur supposed to put it in neutral and use the brakes. beating on ur clutch is using it to do launches.
Old Nov 23, 2006
BigE19's Avatar
No your car will be very laggy. My friends VW had this problem. Throwing codes meaning is there an engine light? when you plug in a obdII scanner it reads you a code telling you whats wrong.
Old Nov 23, 2006
BigE19's Avatar
Could also be a bad mass air flow sensor.
Old Nov 23, 2006
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
your current problem is the clutch or transmission, but if you don't take care of the timing belt soon it'll become a problem later on, I did timing belt, gasket and water pump @ 150k.
Old Nov 23, 2006
AznSaint's Avatar
did you mean that you changed the timing belt, gasket, and water pump? which shop if so and how much roughly for all three?
unless you diy?
thanks.
Old Nov 23, 2006
AznSaint's Avatar
ic, thanks. and no, there was no engine light... so that should be a good thing.
hey...are you willing to part with your rear seats only?
Old Nov 23, 2006
AznSaint's Avatar
ic, thanks.
i do find myself at times depressing the clutch at red lights... using it for a rolling start... by semi depressing the clutch <--- if that makes any senses.
even though i did that... it can do that much damage that my clutch has worn out literially at 145k....?
Old Nov 24, 2006
MrXclusivE's Avatar
unless you diy?
thanks.
my buddy helped me do it, it cost me around 400 including the parts
Old Dec 10, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
check the pcv or engine components...basically get a tune up
mikemc422
Aug 9, 2018 05:41 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
GH04si
Apr 15, 2015 08:13 PM
BREADFAN
Apr 15, 2015 08:58 AM
ImmortalEX
Oct 31, 2001 10:00 PM
