Air filter assembly jammed
Old Dec 9, 2009
redrazr's Avatar
redrazr is an unknown quantity at this point
the air filter assembly is jammed and i cant open it to change the air filter, the screws wont rotate, probably because the screw is rusted or something.
what can i do?
do i need to change the whole assembly?
Old Dec 9, 2009
CraigW's Avatar
Re: Air filter assembly jammed
I would LIGHTLY soak each exposed screw head with PB Blaster or WD-40 and allow it to soak for a while. You may need more leverage to break them loose, but be careful you don't crack the lower case where the threaded inserts are.
These screws are prone to get tight from slight rusting that occurs, put a tiny bit of lube in the inserts before threading the bolts back in.
Old Dec 9, 2009
the screws are really easy to break and if they are stripped, youll need a new box.
Old Dec 10, 2009
redrazr's Avatar
yea replacement of the whole assembly is pretty expensive. Can i just replace the whole thing with a cold air intake? i found cheap CAI assembly on ebay.
Old Dec 10, 2009
yeah but stick with name brand, the cheap ones are junky and dont fit right.
tock172
Jul 21, 2015 06:25 PM
vtecbrah
May 12, 2015 01:30 PM
carid
Apr 30, 2015 07:00 AM
