Side Molding Coming Loose
Old Nov 20, 2009
highwayman's Avatar
highwayman is an unknown quantity at this point
the side molding on my '04 civic sedan is coming loose where the front and rear doors meet. the small clamp that holds it in place in the hole in the door is broken. i have the replacement clips but i'm wondering if it can be replaced from the outside or do i have to remove the panel to get at it from inside the car. thanks.
Old Nov 20, 2009
Re: Side Molding Coming Loose
need to remove the door panel to pop out the whole piece. i wouldnt try bending it from outside.
Old Nov 20, 2009
highwayman's Avatar
thats what i was afraid of. is there a link somewhere on here on how to remove those panels? do i need a special tool to remove the window opener (i don't have pwr windows). thanks.
Old Nov 20, 2009
ya theres a tool for the window, most auto store carry it. other than that, its pretty easy. just pry off the plastic cover behind the door handle on top, then remove the two screws behind it. detatch the door handle from the metal bar by unhooking the clip, then pull it off. pry off the arm rest lower plastic cover, and there are two screws inside there. once those are off, you can just pull the door off. there are clips all along the outside edges so just reach in and pull. once its loose, push the panel up and then out. unplug any wire harness, if any. remove the plastic cover inside and you should see the clips for the molding.
Old Nov 21, 2009
highwayman's Avatar
thanks. once i had the door panel off and looked at how the moulding was clipped into place, i realized that i didn't have to take it off after all. the clips slide over the piece on the back of the moulding and then just push it (the moulding with the clip on it) back into the hole in the door. at least now i know how to remove the door panels. i appreciate the info.
Old Nov 21, 2009
its really hard to slide off tho. i tried that when i was changing one of mine and it woundnt move. also didnt want to scratch the paint.
Old Nov 22, 2009
highwayman's Avatar
the two clips i was replacing were already broken. also, they were both at easy spots to get to, where the back and front doors meet.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
crowtoo
May 11, 2015 06:50 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
