Headlight/Blower Problems
Old Oct 31, 2009
gpm1us's Avatar
gpm1us is an unknown quantity at this point
Having some electrical problems on my 05 Civic LX. This problem is somewhat intermittent but is now pretty much the norm.
Symptoms:
RF low beam does not work.
R turn indicator comes on when headlights turned on. Right turn signals do not function when headlight switch is on. Functions fine when headlight switch is off.
R turn indicator comes on when the A/C switch is pressed on. Right turn signals function but in a slower manner.
Blower motor shuts off when headlight switch is turned on.
Dash brake light comes on when headlights are turned on or the A/C is turned on.
Troubleshooting done:
Battery/Alternator OK
Swapped headlights - problem remained
Swapped headlight relays - problem remained
Checked fuses - good
Check continuity in the headlight / turn signal assy. - all good
Did troubleshooting on the Multiplex Control Unit up to swap the unit out.
Any suggestions before I put down about $240 for a replacement? This is for my son's car and I am out of work right now so I would like to be sure.
Thanks in advance.
Old Nov 1, 2009
CraigW's Avatar
Re: Headlight/Blower Problems
You have a tough one here for certain. The turn signals are certainly part of the under dash box, BUT I cant see any way they are tied into the multiplex system though. It would be an expensive gamble.
My other thoughts are a poor ground somewhere.
You might try gently moving the connectors feeding in/out of the under dash fuse box and look for changes in the symptoms.
Old Nov 3, 2009
gpm1us's Avatar
CraigW - Thank you for your reply. This has been a tough one. I buttoned everything together today and except for a few brief periods of acting up the car performed fine for the rest of the day. I will pull out the manual and run through the grounding points. Of course if it is not acting up then it is hard to troubleshoot...........
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
