external Magnetic trans filter
Old Oct 16, 2009
brian02's Avatar
brian02 is an unknown quantity at this point
Has anyone used this magnetic in line trans filter? You can spice it into your trans cooler liner or your power steering line. Seems like a good idea as in our civics there is no external trans filter. Here is a link
http://www.emergingent.com/subpage1Magnefine.htm
Any one use this thing?
Old Oct 16, 2009
Re: external Magnetic trans filter
i doubt that would work. first, you need a trans filter that is "oil filter canister style" because their addon seems to only work with that system. second, we have a magnetic drain plug that already pulls most of the metal out of the fluid. my first two fluid changes i noticed alot of metal on the plug, but after that there is hardly anything. its only during the initial breakin period that you have to worry about metal shavings. after 20k miles no more are produced. same goes for the engine oil. the magnetic plug i got for that pulled some particles the first time, but after that its completely clean.
May 4, 2016 07:14 AM
alaga
Feb 28, 2016 02:19 PM
jdub122
Sep 5, 2015 09:06 PM
Dangerousjordan
Jul 27, 2015 03:43 PM
