Problem with the power window.
Old Oct 13, 2009
Cygnus's Avatar
Cygnus is an unknown quantity at this point
Hi, pals.
I am going to buy a 2001 Honda Civic Coupe EX, but yesterday while taking a look on it I saw something which confused me. The when I press the button for the left window to go down and then remove my finger on it, the window didn't stop, but just went complitely down. So in order to stop the window at the level I wanted, I had to press the button twice. Is that normal? I mean, on the other cars when you remove your finger from the button, the window stops sliding down immediately at the desired level. No with that car. How is the situation with your civics? Thanks.
Old Oct 13, 2009
CraigW's Avatar
Re: Problem with the power window.
Normal operation "Auto Down"
Old Oct 13, 2009
BOB INDO's Avatar
BOB INDO is an unknown quantity at this point
Originally Posted by Cygnus
Hi, pals.
I own a 1994 civic ex..same thing with my car, i guess that's the way they made it...now my right power window creeps going up..any idea whats causing that?
Old Oct 13, 2009
BOB INDO's Avatar
Hi, pals.
Old Oct 13, 2009
CraigW's Avatar
I would start by pulling the door panel and cleaning the lower front and rear rubber tracks where the window slides, and also clean the upper tracks on the door. Make sure the rubber inserts are in the channel and not folded or misformed. Use simple green and some rags.
Lube the moving,sliding and pivot portions of the regulator. If there is a cable apply lube to it as well. Use white lithium grease.
The 6th gens have a different style regulator than the 7ths.
Old Oct 13, 2009
there are two stops on the auto button. if you press it gently it will work like normal. if you press it down hard, it will roll down all the way.
Old Oct 13, 2009
and if the window is moving by itself, you may have a problem with the switch. usually opening it up for cleaning and realigning the mechanism should fix it.
Old Oct 13, 2009
BOB INDO's Avatar
Thanks!!
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
dennis123
May 3, 2015 03:14 PM
supercivic01
South
Nov 30, 2001 11:27 AM
