Problem number 2!
Old Oct 2, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Problem number 2!
Ok!
Hopefully gearbox or one of the other fine lads on here can help me out.
Actions done so far. I've clean the throttle body, Valve on the side of the throttle body, intake filter (K&N drop in) and changed out the spark plugs (NGK IRID.). I was reading some of the other post and i'm going to check the Gap tomorrow to rule that issue out.
The problem:
When driving (even while coasting) the engine will start to stumble and lose power. I stepped on the gas once to try and prevent the engine from dieing and the engine will bog down and then it jumps back up. with in 15 mins it died on me 3 times. After the car dies and i'm pulled over on the side of the road the engine WON'T start. I can hear the starter motor going and i'll wait like 2 minutes and tty like 3-4 during that time. After the fifth time it will start.
I'm not getting any kind of smoke of any kind out of the tail pipe and im not losing coolant. Also when I changed the spark plugs (two days ago) I didn't have any oil of any kind. I haven't checked the Coil and I plan too in the morning. My only other thoughts is that it's the fuel pump dieing. I'm not one hundred % sure but It could be the fuel pump starting to go out and so when the engine dies out and I try to start the engine again theres no fuel in the lines while i'm trying to start it. I know it should be pressured but if the fuel is being held back because of the pump??? Help me out of this guys because i'm really getting tired of the D17 acting up on my like this! does the fuel pump have a sensor that reads whether it fails or not?
FYI I don't get any codes, CEL, or any of the sort at all.
Old Oct 2, 2009
Re: Problem number 2!
Also I forgot to state this, I also reset the ECU and then did the Relearn.
Old Oct 2, 2009
throw out the K&N filter and get a good paper like napa gold, or a good oiled foam like amsoil (if they make it). otherwise you will just clog everything up again. you might as well use a piece of toilet paper as a filter if you trust K&N. fuel pump is a likely cause of your problems, that or clogged injectors. but it sounds like your fuel pressure is dropping while driving and thats why youre losing power.
Old Oct 2, 2009
So Go for the fuel pump?? Yeah i hear with K&N they don't filter a much which is why your able to get that few extra horsepower, which means you have to do oil changes all the time.
Old Oct 3, 2009
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Could just be a clogged FUEL filter.
Old Oct 3, 2009
possible but those filters are rated for 100k miles or more and are not easy to change. technically you should never change it for the life of the car, unles ofcourse there is a fuel pressure drop. but if it was clogged, you would have consistent drop and the car would never run. his sounds like sometimes it works, sometimes doesnt.
Old Oct 5, 2009
Fuel pump changed so far so good!
Old Oct 5, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Check ur fuel filter... It might be that, or a pump.. cuz it sounds like u losing fuel..
Old Oct 5, 2009
did all of the above! every thing is good so far.
Old Oct 5, 2009
Well, then it might be a injectors cloged up like gearbox said..
Old Oct 6, 2009
Ok here's what I got. The problem came back today but it was alittle bit different. Normally when I had the problem the RPM's would slowly go down and die. This time the engine just shut off. No codes still. I Changed the fuel pump, looked at the filter (looked fine) and still hadn't had any luck. The only real change is that when it dies I'm able to start the engine up right away insteed of having to wait. Does anyone have any more info on the injectors??? I think i saw in another post that they have to be sent off to be cleaned. Could I try some Fuel injector cleaner from the store first? I'm really starting to run out of ideas on what could be happening. The only real thing that i'm thinking about is a faulty Fuel pressure Reg. what do you guys think?
-chris
Old Oct 6, 2009
try some FP-plus from lubecontrol.com
Old Oct 6, 2009
U can clean em with some 40dw..
Old Oct 17, 2009
ok Here's whats up. So far the Spark plugs are new, the fuel pump is new, i've cleaned the IAV valve + throttle body and I cleaned my intake. So I ran into the problem once again and desided to test some thing else.... I took the spark plugs out one by one and attached them to the coil. After that I had my wife crank the motor and noticed something intresting. The #3 cylinder spark Arc looks normal but the other three cylinders where so weak I had to close one eye and hold it up to a black back ground only to see LITTLE to no spark on the other three. I have 4 new ignition coils coming in tomorrow at 9AM so Hopefully all is good once I've changed them. So From what I understand it's just 4 coils, the PCM and thats it? I know ignition timing is also linked to the CPS and TDC sensor, are there anything else involved?
Old Oct 17, 2009
all you can really do is change the coils. but, have you measured the incoming voltage to the coils? make sure that with the car running they are putting out 13.9v each. grab a multimeter and tap into one of the three wires, i think the brown one. whichever is constant power so you get a reading.
Old Oct 18, 2009
Sure thing i'll find out today and hit you up with the update later!
Old Oct 18, 2009
Ok all ignition coils have been replaced. So far the car hasn't died on me after a test drive. It seems to have restored power and respond's well. The only thing that i've noticed is that I still have the problem with RPM's. When the car is coming to a stop and the RPM's get to 900 it will jump back up to around 1400 rpm and go down from there. The RPM's seem to hop up and slowly go down every time. Does anyone have any Idea why this is?
Old Oct 18, 2009
ECU relearn completed! Going for another test drive!
Old Oct 18, 2009
if the rpm is jumping up and down by itself, it may be a bad tps sensor, and that means new throttle body time. but if its just idle drop when you let off the gas, its prolly just the dirty iac and the cleaning + relearn should fix it.
Old Oct 18, 2009
Yeah It's not all the time. It only jumps up while the RPM's are going down after i let off the gas and let the tranny slow the car down. I've already cleaned the IAC and just did the Relearn so far so good. I forgot to look while I was driving it but so far so good!
Old Oct 19, 2009
Ok I'm throwing in the towel. The problem came back this time it was kind of crazy. It died on me today and when I tried to start it it sounded like one of the cylinders fired and then died right away. I tried like 5 times to get it to start and desided to disconnect the battery for 10 mins and reset the computer. After I did that guess what the car started right up. Could the strange idle drop and the car killing itself along with the start up after the Reset mean that the PCM is no good? I'm really getting tired of this and I really really need to fix this. I unplugged the MAP sensor to make sure the ECU picked up the code which it did and then i reset it. So far with all of the work i've done that's the only thing that makes sence to me is that the control unit is ****ed! Does anyone have any ideas??
Old Oct 19, 2009
Do u get any kind of warning lights on ur dashboard before it dies out?
Old Oct 20, 2009
no = (
Old Oct 20, 2009
Well, here is what i would do, I would take it to the dealership and pay 40 bucks to them to put the car on their computer and have an mechanic explain to me, what is wrong with my car.. Because i really dont know what else could be wrong with it either, If u did all of those stuff that u said u did, then i dont know.. Thats the best thing to do for u now.
Old Oct 20, 2009
they will say everythings fine
Old Oct 20, 2009
Agreed! How do I know?? I just got off the phone and after talking to honda and after a good 10 mins he told me that it really wouldn't be worth me taking the car down there because more then likely they're computer wouldn't pick anything up at all. I'm going to look at the PCM, the service rep told me to open up the PCM and look for any damage. He told me that for the most part he's never seen a PCM just go bad and that most of the time its just water that drips in from the wiring harness and drips into the PCM. He was a cool guy actually hes been working there for 22 years he took down my number and hes going to have his head machanic call me so we can discuss it. hopefully we can get this fixed!
Old Oct 20, 2009
Yea, i mean that never has happend to me, but it can happen... i hope u get it fixed..
Old Oct 20, 2009
Heck yeah! I need to try and change the Relays and then if that doesn't work..... The PCM. Honda said its going to cost like $500!
Old Nov 1, 2009
Okay, after getting a ECU off of a good source from E-bay I've swapped them out and the Car is at Honda. Hopefully tomorrow I get a call saying she's ready to roll!
Old Nov 2, 2009
every thing works yay!!!!!!!!!!!!!!!!!!!!!!!!:rockon :
