diagnostics help
Old Aug 10, 2009
aschattke's Avatar
aschattke is an unknown quantity at this point
diagnostics help
I need help figuring out what my car is doing.
When the car sits longer than like 30 minutes when I get it in and go to drive away it just bogs down and wants to die. Once I toy with it for about 2-3 minutes I can get it going and it runs completely normal for the rest of the trip. It is becoming quite annoying. Any suggestions?
I was thinking possibly fuel filter.
Old Aug 10, 2009
Re: diagnostics help
maybe dirty iac valve or throttle body since it seems to only do it when cold. fuel filter would cause problems all the time.
Old Aug 12, 2009
Tomj333_EM2's Avatar
Tomj333_EM2 is an unknown quantity at this point
Agreed sounds like a combination of bad iac/cold plugs and maybe its getting the wrong fuel air mix?
Old Aug 12, 2009
aschattke's Avatar
when i get the iac valve out of there is there any way to tell if its bad or not cause I justed priced a new one and its like $260 from napa.
Old Aug 12, 2009
spraying it inside with carb cleaner to remove all the black carbon will fix it. those almost never go bad.
Old Aug 13, 2009
aschattke's Avatar
is it me or are those three screws impossible to get out? They are locked up and it just doesnt seem like i can even get close to getting enough torque on them with just a screw driver to get them to break lose.
Old Aug 13, 2009
they are very hard to remove the first time. you gotta get the perfect size bit and push down hard while turning. spray them with liquid wrench too it helps.
Old Aug 14, 2009
They are hard, i dont need to warn you that you cant really afford to screw up taking them out < no pun intended >
But yeah, get the right bit and apply lots of downward pressure on the driver. Make sure you loosen each one before removing completely as there's a tiny little gasket inside you dont wanna lose.
Old Aug 14, 2009
TRIZ's Avatar
I never took those screws out so I dont know how fragile they are, but it sounds like you need an impact screwdriver
Old Aug 14, 2009
aschattke's Avatar
i was thinking about the impact as a last resort but i ended up getting them out with the right lenghth screwdriver and right bit. Now that I have it off do I have to replace the gasket when i put it back on? Should I try and wipe the carbon build up with q tips or something or just get it as clean as i can by spraying? Should I spray up in the throttle body and clean in there as well? Also while it is off besides cleaning the iac valve should I do anything else with the throttle body?
Old Aug 14, 2009
aschattke's Avatar
Should I wipe down in the iac valve with a q tip or something or just get what i can by the spray? Should I clean up in the throttle body?
Old Aug 14, 2009
aschattke's Avatar
Old Aug 15, 2009
aschattke's Avatar
Anybody?
Old Aug 15, 2009
aschattke's Avatar
ok, so i just sprayed and scraped all the stuff out of the iac valve and a little where the iac valve connects to the throttle body. I put everything back together and it still did it. I put it in drive and it will start moving but after I give it a little throttle it just bogs down. I replaceced my cone filter as well.
Old Aug 15, 2009
yeah you want it to look like new. scrub all the black stuff out. are you getting any check engine light? is the rpm just dropping and stalling? did you remove the throttle body? if you did, you must do the ecu reset and idle learn procedure otherwise the idle speed will fluctuate. warm up the engine and turn the car off, disconnect battery, reconnect, start car, let it idle for 10 mins without using accessories or pressing gas. shut off car, then start again. idle should be set. if that doesnt work, you have a different issue like possibly spark plugs, clogged injectors, etc.
Old Aug 15, 2009
Old Aug 25, 2009
aschattke's Avatar
ok, i hate to bring this thread back but im still having issues. Once I cleaned the iac valve, it stopped doing this all the time and started doing it about 60% of the time. I tried to find some sort of pattern with no luck. So I changed the spark plugs (bosch platinum) and since then it hasnt done it. However, it does have some hesitation sometimes like it wants to bog down but it doesnt. Furthermore, it has been running real sluggish. When I did the iac valve I didnt take the throttle body off I just cleaned what I could where the iac valve meets it. When I did the iac valve I also changed my air filter. Before I did the iac valve I ran a tank of premium through with a can of sea foam. I think it is the fuel injectors but I am not sure. I was gonna try some more fuel injector cleaner. Any suggestions on what to use? Any other thoughts on what it could be? Car has 86,xxx miles
thanks for the help, it is much appreciated
Old Aug 26, 2009
its hard to say. make sure you use only ngk or denso plugs. could be clogged injectors or even a clogged cat converter. usually idle issues are caused by iac valve being dirty, pcv valve, or dirty injectors not spraying in a mist pattern.
Old Aug 26, 2009
aschattke's Avatar
why use only ngk or denso plugs?
Old Aug 27, 2009
cause they were made for hondas. bosch and other brands will cause engine problems. i had 3 people over the last month pm me for hesitation and engine bogging issues and they were all using bosch plugs. i told them put in some cheap ngk copper plugs and everything got fixed.
Old Aug 27, 2009
aschattke's Avatar
do you order straight from there website or will napa/autozone carry them?
Old Aug 30, 2009
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
I am having the EXACT same problem right now. I have no check engine light on, and the dealer I brought the car to couldn't replicate the problem. I am trying to sell this car but can't with this nagging issue.
It sounds like I should start by cleaning this valve, and if that doesn't work, try replacing the plugs?
Old Aug 30, 2009
aschattke's Avatar
if you figure it out let me know asap
Old Aug 30, 2009
04 Honda Civic's Avatar
aschattke-change the plugs like gearboxs said if you spend more then like $15 then ur buying the wrong ones. You want the most basic single prong ngks or denso.
NBP- I say u clean your throttle body and IAC as well. When I had a rough idle it wasnt my problem either, but it never hurts to have a clean IAC and tb.
SimpleUser
Apr 24, 2021 02:54 AM
sesi
Oct 1, 2015 02:03 PM
michael0219
Sep 1, 2015 10:25 PM
Jwzy
Aug 24, 2015 09:35 PM
JetsterDajet
Aug 16, 2015 01:56 PM
