Slight Shaking while driving 65-80mph
Old Aug 10, 2009
05blueexcoupe's Avatar
05blueexcoupe is an unknown quantity at this point
Unhappy Slight Shaking while driving 65-80mph
I have a 2005 Civic Coupe with 64,500 miles on it and just recently there has been some shaking coming from the front end while driving at highway speeds. Does anyone have any idea what it might be from. Brakes and steeleys are still the original. Thanks.
Old Aug 10, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: Slight Shaking while driving 65-80mph
I'd go get the tires balanced and go from there.
Old Aug 10, 2009
04 Honda Civic's Avatar
What do your tires look like? Do they look cracked and warped? Might just be time for a new wheel balance.
Old Aug 10, 2009
BlueEM2's Avatar
Whachya lookin at?
Check your tire pressures first. A real low tire can cause shaking. Then go get your wheels balanced. If it still persists get your front end checked out, if everything is okay get an alignment.
Old Aug 10, 2009
FALKEN's Avatar
Civicforums Junkie
Sounds like the tire balance.
Old Aug 10, 2009
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
You have a 2005 ex that came with steelies??? Anyway it's your balance. Happened to me after I got new front tires. Only noticable around 65ish and up? Got the front tires balanced and good as new.
Old Aug 14, 2009
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Have you ever washed your car while the rotors are still hot and have steam come off em? Cause that is what I did and it warped em. Same EXACT symptoms. It will give you a reason to buy drilled and slotted rotors! Give it a try.
Xuhme
21
Aug 7, 2023 03:40 PM
smmahan
Apr 15, 2015 08:17 PM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
RickyRocket
Nov 30, 2001 10:14 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
