o2 sensor replacement
Old Aug 4, 2009
crusher's Avatar
crusher is an unknown quantity at this point
Hi all 1st post here...
I have tried to use the search function and got some answers but not everything I was looking for.
My engine light just came on yesterday and it has been put down to a new o2 sensor. This is my 1st Honda and I was not ready for the cost of replacing it... My local shop wants to charge me approx $480 CND for parts and labour...
I have a 2005 DX/SE.
My question is what is really involved in replacing the o2 sensor?
Going by the diagram here it doesn't look that difficult to get to.
http://www.hondaautomotiveparts.com/...C+VTEC+LEAN%29
Thanks in advance and sorry if this has been covered elsewhere on the site.
Old Aug 4, 2009
unTuned's Avatar
Re: o2 sensor replacement
ah yes. the beloved 'first dealership quote'. be prepared for many of those to come.
anyway its extremely simple to change. you will laugh at what they want to charge when its all done. you can either purchase one from the dealership which will be a bit more expensive, you can go to a wrecker and see if you can get one there, or you can buy one online (like i would).
http://cgi.ebay.com/ebaymotors/Oxyge...Q5fAccessories
it isnt very hard to get at. if you lean into your engine bay and look down you should be able to see it. that particular one would be easier to get at from underneath the car. just be sure thats your problem though, you dont want to go out buying parts or doing work if that isnt your problem.
Old Aug 4, 2009
crusher's Avatar
Thanks very much...
Old Aug 4, 2009
BlueEM2's Avatar
Whachya lookin at?
BE AWARE!!!
I have heard bad things about aftermarket O2 sensors. I don't have any personal experience with aftermarkets but from other posters I hear they only last 6 months. From the other post it also sounds like it can cause some damage.
( Again, I can't vouch for this, just from others experience )
Old Aug 5, 2009
unTuned's Avatar
i completely agree. i am very careful especially when it comes to anything mechanical. in this case, the one on ebay is a denso sensor which should be the same as the stock one. i dont see how it would be a big risk in this case. if it was some knockoff or no name, i would go get one from the dealership.
Old Aug 5, 2009
crusher's Avatar
I have sent an email to the ebay store to ensure they have the proper sensors for a 2005 DX/SE civic.
The prices are just scaring me a little... how come such a differance between the Denso and the Honda units?
Old Aug 5, 2009
unTuned's Avatar
i dont think its that big of a deal. anything with the name 'honda' on it is like that. if you look closely at your car, theres a bunch of **** in your engine bay that are denso. honda uses denso right from the factory as well, so youre safe. if it wasnt honda or denso i wouldnt suggest getting it. but i would still make sure and email them asking if anyone else who has purchased it has had any problems.
Old Aug 5, 2009
crusher's Avatar
Cool thanks!!
Just waiting on the parts supplier to get back to me with the part #'s needed.
Thanks all!!
Old Aug 5, 2009
unTuned's Avatar
np.
and where is everett?
Old Aug 5, 2009
crusher's Avatar
About an hour north of Toronto. In the sticks
Old Aug 6, 2009
BlueEM2's Avatar
Whachya lookin at?
Cool, I work in Hamilton. It's about an hour and a half away from you.
Old Aug 6, 2009
2k5reverb's Avatar
2k5reverb will become famous soon enough
hey man i was having the same problem with my civic about 6 moths ago. I took it to honda and all i needed was my ecu to be updated. Tell honda to look at service bulletin 07-019. That might fix it.
Old Aug 9, 2009
unTuned's Avatar
2k5reverb, did it cost anything? or did they do it under warranty? i would try doing that too before replacing a sensor.
Old Aug 9, 2009
2k5reverb's Avatar
No i never paid anything it was under warranty. I just phoned honda and told them the issue and told them about the service bulletin. It took about 15 to 20 min for them to fix it. If you want a copy of the service bulletin just let me know.
Old Sep 3, 2009
mclean987's Avatar
mclean987 is an unknown quantity at this point
can i get a copy of tsb please, thanks
Old Sep 4, 2009
anderson's Avatar
anderson is an unknown quantity at this point
Old Sep 4, 2009
2k5reverb's Avatar
Here is a copy of that service bulletin
sorry it is a pdf i couldnt figure out how to post it as a picture.
File Type: pdf
Old Sep 11, 2009
madAd's Avatar
madAd is an unknown quantity at this point
Bosch also makes good sensors. They are the OEM type, you'll want to make sure that it has the OEM connector on it. I got mine for $50 @ Autozone , but I don't know what you guys have for parts stores in Canada.
Old Sep 11, 2009
yeah the oem NTK sensors are the same as bosch (rebranded NTK).
Old Sep 12, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Its pretty simple. Buy sensor. Unclip from harness. Unbolt from flange (10mm??) remove sensor and old gasket. Replace using reverse order.
Old Sep 12, 2009
an 02 sensor socket with cutout for the wiring helps too
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
SQCivic
Jan 23, 2002 07:42 PM
