Complete DIY's on starting, charging, engines, trannys, etc.
Old Jul 30, 2009
Spartanic's Avatar
Spartanic will become famous soon enough
Thumbs up Complete DIY's on starting, charging, engines, trannys, etc.
How's it going guys. Here are some completed DIYs that you guys might find helpful. The repair info isn't model specific but does give you a general idea of how certain parts work. Let me know if you guys see any errors.
- Anti Lock Brake Safety Information (ABS)
- Air Conditioning Troubleshooting - No cool air, noisy AC, etc
- Ball join check
- Brake System Troubleshoot - screeching noise, dragging brakes, etc
- Break-in procedure for new engines
- Camshafts - removal, cleaning, inspection and installation
- Charging System - No start, Noisy alternator, fuses burn out quickly, battery not charged
- Clutch Troubleshoot - chattering, rattling, slipping, stiff pedal, and more
- Cooling System - overheating, low coolant, refilling, flushing, and more
- Crankshaft and Main Bearings - removal, cleaning and inspection, installation and more
- Cylinder Head Overhaul - removal, cleaning, inspection and installation
- Drive Axle - Clunk Noises, Gear noises, vibration, and more
- FF Axle Shafts and CV Joint Troubleshooting
- RWD Drive Axle Troubleshoot - clunking noises, vibration and more
- Troubleshoot hard starting, rough idle, slow acceleration, Misfire, poor gas mileage, etc.
- Electrostatic Discharge (ESD)
- Emissions Inspection - PCV, TAC, Evap, Catalytic Converter, EGR and more
- Engine Services - bead blasting, cold tank, steam cleaning,
- Engine Damage Inspection - Magnaflux, Zyglo, Dye Check, Ultrasonic, X-ray
- Engine Overhaul - cleaning, cylinder head, pistons, rods, crankshaft and more
- Engine Troubleshoot - rough idle, hesitation, backfire, detonation, low oil pressure and more
- Fuel System Troubleshooting - Hard starting or no-start, ping on acceleration and more
- Heater System Troubleshoot - Low or no heat, blower not working and more
- Troubleshoot ignition system, no-start, engine runs rough, etc.
- Proper vehicle jacking and wheel removal procedures
- Manual Transmission Repair - Troubleshooting noisy gears, gears clashing, hard shifting, etc
- OIL PUMP - Rotor and Gear type
- Parasitic Load Explanation and Test Procedures
- Pistons, Connecting Rods and Bearings - removal, cleaning, inspection
- Power Steering Troubleshooting
- Safety in the Garage
- Spark Plugs - troubleshooting, carbon deposits, electrodes, etc.
- Starter Troubleshooting - no start, no clicks from solenoid, etc.
- MANUAL STEERING GEAR TROUBLESHOOTING
- Suspension alignment troubleshoot - tire wear, odd suspension noises, etc.
- Tie rod test
- Timing Chain and Belts - tension adjustment, gear backlash, runout, etc.
- Undercarriage Quick test - this finds loose suspension parts that need replacement.
- Warped Rotors - this test helps determine if your rotors are warped.
- Wheel Alignment Operations - camber, caster, toe, steering axes and more
- Wheel Bearing Quick Test
Old Jul 31, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Complete DIY's on starting, charging, engines, trannys, etc.
It says FORBIDDEN! Won't let me into the website at all.
Old Jul 31, 2009
edwin101988's Avatar
edwin101988 is an unknown quantity at this point
Same here ^^
Old Jul 31, 2009
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
3x...
Old Aug 8, 2009
BlueEM2's Avatar
Whachya lookin at?
It seems to have started working.
Old May 29, 2011
intrance9's Avatar
<3 my si
intrance9 is an unknown quantity at this point
nice thread!
Old May 29, 2011
oh, it have been moved to the 7th gen section! sweet! who is gonna host this in the sig? mine is full
Old May 29, 2011
lazlong's Avatar
How's that?
Old May 29, 2011
yeeah!
Old May 29, 2011
MindBomber's Avatar
Live for the Twisties
I moved it over a couple days ago
I was thinking about making DIYs with pictures of all the simple suspension tests this summer and possibly one for proper wheel removal. There's a million of those write-ups out there on youtube etcetera, but it might be good to have our own.
we'll see how bored i get
Old Jul 8, 2011
xaxixuxexo's Avatar
xaxixuxexo is an unknown quantity at this point
It doesnt seem to be working for me
Old Jul 8, 2011
Thread closed. Dude hasn't been on since 2009, none of the links work, and garage411.com doesn't work either.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
Grazzhopper
Nov 11, 2001 08:06 AM
artychris
Nov 10, 2001 01:06 PM
