Battery Alternator Troubleshooting Quesitons
Old Jul 19, 2009
leeave96's Avatar
leeave96 is an unknown quantity at this point
I am having some battery and potential alternator problems I want to trouble shoot.
1. Went to start the car in 90ish degree F weather and the battery wouldn't turn the engine. Clicking sound when trying to crank, but dash lights working.
2. Jumped the car and the alternator was charging about 14.5 volts.
3. Drove away and the dash lights started blinking a bit and the radio would loose it's station setting. After seeing this, I remembered over the past month or so, the radio would loose it's setting at random.
4. Prior to jumping as per above, looked at the battery and found it to be low on fluid down to where the top of the cores were visible. Refilled with water.
What's going on with my car? Is the battery just shot? Is the alternator putting out to much and boiling out the battery fluid? Is the alternator shot?
Right now, I've got the battery on a charger to see if it will take and hold a charge before I go out and buy another. If it will charge and hold, maybe it's not the battery.
Any advice would be appreciated.
Thanks!
Bill
Old Jul 19, 2009
DDragon7's Avatar
Re: Battery Alternator Troubleshooting Quesitons
I have a feeling its the battery, the 14.5V when its on is normal.
WaryDriver
Aug 8, 2015 05:08 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
jzhartman
Jul 9, 2015 04:56 PM
