Refrigerant w/sealant question
Old Jul 12, 2009
amos1's Avatar
amos1 is an unknown quantity at this point
I've seen this product in the auto stores,...refrigerant plus sealant. Besides being a quick, short-term fix,...is there any potential for causing damage to a/c components.
Had a '88 suburban that I put radiator stop leak in and ended up blowing the heater core which was a pain to replace.
Thanks for the advice!
Old Jul 12, 2009
Re: Refrigerant w/sealant question
yeah if you do not use the correct oil, the compressor will freeze. the sealant can clog the lines and you will end up with a worthless ac system. those junk in a can are very bad idea unless you have an old beat up ride and you just need some ac for the summer.
Old Jul 12, 2009
denice25's Avatar
Member
denice25 will become famous soon enough
very nice info...
Old Jul 28, 2009
amos1's Avatar
Thanks guys!
Old Aug 2, 2009
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Refrigerant plus sealant is fine in any auto AC system.
The better solution is find the leaking fitting and replace the o-ring. The easiest way to find the leak is to look for an oily/dirty fitting along the AC lines. Also inspect the compressor for oily/dirty spots on the ends of the compressor for gasket failure.
Old Aug 6, 2009
djmota's Avatar
The ac system is very touchy as gearbox said adding a sealant into the system has the potential to ruin components that arent made to handle that. Namely the compressor and or the dryer. if you have a leak take it to a good ac place they will find it witha dye and blacklight and fix it the right way
4jacks
Aug 17, 2015 01:26 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
andyandyy
Aug 4, 2015 06:37 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
