2004 Honda Civic SE starting problem
Hello all,
I am posting here in the hopes of saving myself time, money and agony. I have a 2004 Honda Civic, and the weirdest thing happened today.
I drove my car to the nearest plaza and nothing appeared to be wrong. I went into the store, came back out and to my surprise, the car wouldn't start. I turned the key and all I heard was a consistent clicking noise. This is before I even tried to turn it over all the way to start. When I turned it over to start, the clicking noise got faster. The starter didn't turn at all. No lights turned on in the dash. The radio lights wouldn't turn on. I opened my manual and it asked that I check all of the fuses, which I did. Not one was burned. I was convinced this was an electrical problem. Finally, someone gave me a boost and the car started. As a matter of fact, as soon as they hooked the cables up and I turned the ignition (without fully turning it over), I noticed the radio on, and the normally beeping that I should hear just before I turn over the ignition. The car started fine. Even after it started, I had a feeling it wouldn't start once I shut it off. When I got home, I shut it off and tried to start it again and I was back to square one! Same problem as before! A few hours later I checked my battery cables to make sure there was no corrosion and there was not. Everything was nicely greased and tight. I even cleaned the posts and reconnected the battery and tried to start it again. This time, the battery was completely drained. Only the light that flashes on the CD player flashes, and it's going very, very slowly. The weather outside is perfect, so let's rule that out as a factor in the problem.
Before I'm asked the question, no, there were no warning signs on my dash board about a failing battery or alternator. This doesn't make any sense to me at all. I read something on the net that says something about the Main Relay but I couldn't tell you what the heck it's all about anyways. I have seen some notes about the battery but it seems to be followed by too much doubt. I don't think it's my starter (unless it's warn out inside and it's causing a shortage) or my fuel pump, since the car started fine when hooked up to a booster. Something is up and I really need some help! This doesn't seem like a simple problem.
Re: 2004 Honda Civic SE starting problem
bad battery or alternator I suppose. If u have a voltmeter check ur battery power while u have someone else try to start the car. If the voltage goes below 9 the battery is no good.
Everyone who has alternator problems sees them comming. The Batterly light will be lit up on the dash board for at least a few days comming up to the day it finally is done. I'm not saying you're wrong or right...just saying that this doesn't seem like the problem.
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
chgofirefighter
Apr 18, 2015 08:08 PM
gabrown2
Apr 11, 2015 08:22 PM
