2003 owners manual, driving light info needed
Old Jun 1, 2009
mmtphoto's Avatar
mmtphoto is an unknown quantity at this point
I got a 2003 civic lx for my daughter and have gotten it to the point where I want to get a couple more items-I did not get an owner's manual, and would like a real manual if possible, but will settle for a PDF if I can locate it online (cannot so far)-
also, it needs driving lights, I want to install them in the original location and set them up so that they are always on when running-
So far, it has new tires, new brakes (ceramic) new (mostly) interior, like rugs, mats, seats, since it was pretty ratty when I got it. I changed all fluids including oil and trans (full syn), coolent, brake fluid, and I installed remote door opener (only $40!)-it has some body work done, and new plugs and O2 sensor (upstream)-this car has 105,000 miles, does not leak, and is getting over 30mpg so far (1000+ miles of mostly city driving). Ac has gotten a shot of 134a and is blowing cold (40 degrees)-she loves it,
I am talking to her about giving it a little more OMPHHHH, like a CAI and replacing the tiny exhaust with something better-suggestions on all items welcome, someone GAVE this car to me, so I know I am ahead of the game. It doesnt leak, runs strong, and except for the fact that the 2-3 shift takes FOREVER when the trans is cold, it is a nice little car-thanks
Old Jun 2, 2009
mmtphoto's Avatar
Re: 2003 owners manual, driving light info needed
i found an owners manual on ebay for about $15 deliveed, so I just need to know what lights I should buy-I want to get clear, and really just want to wire it so that it just turns on when the car is started. I looked at the location where the lights should go, it is a small area that looks like it has to be cut out (the front abs plastic)-how are they secured to this location?-do original lights have brackets that I can get?
And does anyone know of a cure for the really slow 2-3 shift? It does go away after the trans warms up, and I suppose it is especially not an issue in warm weather, but whenit gets cold here again, it cannot be good for it to 'slip' like that-thanks
Old Jun 3, 2009
CraigW's Avatar
You must mean fog lamps, you can buy a kit. OEM or aftermarket.
Not sure what fluid you used in tranny but... It should only have Honda ATF-Z1 in there.
Old Jun 4, 2009
mmtphoto's Avatar
yea, I guess I mean fog lights but i don't want amber (fog) lenses/bulbs, I want the lights to be 5000K so that would, I think, make them driving lights-kind of like full-time day lights.
I have done a trans service (twice) and both times I used Honda Z1 (from the dealer, like $8 a quart!)-so I guess my llooooonnnggg 2-3 shift has nothing to do with the fluid, eh?
Old Jun 5, 2009
CraigW's Avatar
Not really sure how far into the 7th gen line the tranny problems will reach ??
Gearbox has driven his quite a while with the slipping present.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
Myredjonda
Apr 14, 2015 07:00 PM
Pwrupd17
Oct 25, 2001 10:04 PM
