Auto Tranny Problems (go figure)
Old May 12, 2009
phaze1todd's Avatar
phaze1todd is an unknown quantity at this point
Hi All!
I'm running an '04 LX and have come across some unusual auto tranny problems.
I am hearing noises under the hood that sounds like a turbo blow off valve when the trans upshifts. Under the hood the tranny fluid is spraying (more of a mist, really) around the dipstick and the dipstick is now loose.
Is there a breather or vacuum line I need to check or will a new dipstick fix it.
Thanks,
-Todd
Old May 13, 2009
CraigW's Avatar
Re: Auto Tranny Problems (go figure)
Those dipsticks are very loose but... spraying/misting is not likely due to the poor fit.
Old May 13, 2009
phaze1todd's Avatar
That's what I was thinking. That's why I was wondering if there was a breather or vac line I should be concerned about.
Old May 14, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
too much tranny fluid? did you recently change the transmission fluid?
MajTom
Jun 2, 2015 11:48 AM
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
02Si
Dec 14, 2001 10:26 AM
