This bliner problem is driving me crazy... HELP!
Old May 9, 2009
mkollek's Avatar
mkollek is an unknown quantity at this point
Okay hers the story..grab a beer and enjoy...
Hazard lights work
left blinker works
right blinker is at hyper speed!
BULBS are OKAY
SOMETIMES the blinker decides to go back to normal but it goes back to hyper speed soon there after.
WHEN I...
1) turn on my lights, the right blinker doesnt work at all
2) when i turn on the AC the right blinker doesnt work at all
3) when the cooling fan is on the right blinker doesnt work at all
ALSO..
Havent figured it out exactly when but sometimes the AC doesnt want to turn on either... or turns on and then shuts off soon after
I think MAYBE when the cooling fan turns on
OH... almost forgot...
when i turn off the car take out the key turn off all the lights and the cooling fan stays on the right blinker/side marker light stays on.
SO.... any takers out there? who wants to take a stab at this one... PLEASE HELP!!!
Old May 9, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: This bliner problem is driving me crazy... HELP!
what was the last thing you did to your car? did u change any relays? did u wash ur engine bay?
Old May 10, 2009
mkollek's Avatar
Last thing i did.. i had no horn hooked up, i installed an airhorn but i dont have relay so i tried it straight to the battery and ground to test it it worked fine but since i dont have a relay i didnt hook it up. I connected back up the OEM horn which works fine and has been working in the past. nothin new. No specific mods.
Old May 10, 2009
bigmacnfrys's Avatar
bigmacnfrys is an unknown quantity at this point
It's sign language?
Old May 11, 2009
mkollek's Avatar
Anyone got any ideas?
Old May 11, 2009
Could it be this:
https://www.civicforums.com/forums/3...c-problem.html
Since its AC related?
Old May 12, 2009
mkollek's Avatar
How do I test if the ac relay is working correctly? Or any of the other relays?
Old May 12, 2009
CraigW's Avatar
Here is the procedure for testing the relays. Sounds like a real strange issue for sure. At first I was thinking bad ground but...
File Type: pdf
Old May 13, 2009
mkollek's Avatar
alright bad ground.. Any other ideas? Anybody know if the multiplexor controls the turn signals aswell? Could it be that from the ac problem?
Old May 13, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Your wiring's ****ed. The resistance on the turn signal wire needs to be exact or else it'll hyper blink like that. That's why people have to install a resistor when putting in LED turn signals, because they draw less amperage and therefore need some sort of resistor to bring the wire's resistance back to normal. This would also tell you why the bulb is not working when other components are on, it's draining too much power from that line. And the lights staying on after the car is off.....well, you messed up something in there. Start removing aftermarket parts until it works again.
Old May 23, 2009
mkollek's Avatar
so bad ground it was!!! good job guys! there is a ground wire by the right headlight attached to a bolt and the bolt was loose. done! awesome guys!!
Xuhme
21
Aug 7, 2023 03:40 PM
sharp66
31
Jun 12, 2022 08:45 AM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
