Wet Drivers Side Floor
Old Apr 14, 2009
Xplod590's Avatar
Xplod590 is an unknown quantity at this point
i have started noticing that my drivers side floorboard was damp. Now it is starting to get worse and worse. My seat, door, and underneith my seat is not wet at all. Has anyone ever had this problem? or can let me know what to check? thanks
Old Apr 14, 2009
Re: Wet Drivers Side Floor
is it water? do you have a moonroof?
Old Apr 14, 2009
Shredocalypse's Avatar
Shredocalypse is an unknown quantity at this point
Same thing is happening with me. No moonroof and i have no clue where it could be coming from...any help would be very niice..
Old Apr 14, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Check underneath the car, there are these round thingies on the bottom of the floor. They were originally holes where hooks went through the body in the factory that were plugged and then just had body sealer put over them. Sometimes those little buggers can come loose and water will leak in from underneath when it rains.
Old Dec 15, 2009
w_nguyen's Avatar
w_nguyen is an unknown quantity at this point
Sorry to bring back an old thread, but has anyone figured out a solution to this problem yet? I have the same leakage, except on the passenger side. All the windows are sealed, and the rubber weather strips on my doors are fine, but whenever a heavy rain rolls around my passenger side carpeting becomes soaked like a sponge. Nothing else is wet, not even the doorsills... just the carpet, which makes me think there might be a hole in the bottom of the car.
Has anyone got a good fix?
Old Dec 15, 2009
check your window moldings, the black strips that go around the front window. they pop out and sometimes water can leak thru the clip holes and trickle down the frame into the car without you ever seeing the water. you can put some black rubber sealer in the holes and around the clips before reinstalling and should fix it.
Old Dec 15, 2009
w_nguyen's Avatar
thanks gear! when did you become administrator? i remember the good old days when you were just "most helpful guy on 7thgen.com."
Old Dec 15, 2009
lol yeah happened just a week ago.
Old Dec 16, 2009
CraigW's Avatar
Check that the black plastic plug inside the wheelwell is still in place and has a tight seal.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
ashlava71
May 16, 2015 12:54 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
