CEL P1167 - which oxygen sensor for 2001 Civic HX?
Old Mar 28, 2009
raygundan's Avatar
raygundan is an unknown quantity at this point
Got a check engine light on the way home from work yesterday and stopped by Autozone to get the code read. Code P1167 looks to be the pre-cat oxygen sensor, but replacing it with the Bosch part they recommended didn't fix the problem.
I'm wondering if they gave me the right part-- parts are usually cheaper when you don't buy from the dealership, but when the dealership charges $350 and the parts shop only charges $60, you start to wonder.
Can anybody tell me if the Bosch 15710 has worked for them as the primary oxygen sensor in a 2001 Civic HX, or do I need another part? If it has worked for you, I'm probably fixing the wrong problem. I see bits of info here and there that lead me to believe this sensor should cost substantially more (saw one post that called it a "wideband" sensor), and that maybe autozone and checker have some sort of screwup in their parts database.
Old Mar 28, 2009
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Re: CEL P1167 - which oxygen sensor for 2001 Civic HX?
Code P1167 = Primary HO2S (No. 1) Heater System. First, since this O2 sensor was replaced, with the car off, reset the code by pulling the ECU fuse #6 and wait for 20 seconds. Re-insert the ECU fuse and turn on the car. If the code comes back, you may need to buy the correct part.
Check out this link if it helps you. The brand is a Denso cost ~$245.
https://www.civicforums.com/forums/3...lectrical.html
Old Mar 28, 2009
raygundan's Avatar
I had tried disconnecting the battery (cleared the light for maybe a minute or so) and then had autozone clear the code with their little OBD II thing (same result-- clear, but back on maybe a mile outside their parking lot). Do I still need to try pulling the ECU fuse?
I saw that other thread you linked this morning, but they only mention the Bosch sensor in passing. One guy says he heard another guy say it didn't work, but I was hoping for a direct confirmation-- especially since two different auto parts shops and a dozen auto parts web sites all show that Bosch part as the right one.
Thanks again for the help.
Old Mar 28, 2009
It wouldn't hurt to try and pull the ECU fuse. Try returning the Bosch to autozone? But from reading on this thread, your car actually need to have the wideband sensor.
https://www.civicforums.com/forums/1...-question.html
http://www.hondaautomotiveparts.com/...14S5P0_E04.gif
In this picture, you will need #07. I assume you have a manual transmission?
Majestic Honda website is selling the part for $208.66 + shipping.
http://www.hondaautomotiveparts.com/...SOHC%2FVTEC%29
Old Mar 28, 2009
changing the sensor should immediately turn off the engine light. i also remember that the HX uses wideband sensor for at least one of its O2 sensor systems. and those are very expensive. i think the autozone douche gave you the wrong one, or didnt look it up right. you got the bosch oem type with the connector right? bosch = NTK which is what the oem honda sensor is, just cheaper. i think you just got the wrong part.
Old Mar 29, 2009
raygundan's Avatar
I've got the CVT, not the manual. Any difference? (I wouldn't think so, except that it makes me about 80% less cool)
Does anybody know the part number for the right sensor? Majestic has it listed by the picture. I think it's a Denso 234-9005. Also, it almost seems like Bosch is mislabelling their sensor, since so many places list this part as the correct one for the HX upstream sensor. I don't really blame the Autozone guy-- as far as I can tell, he looked it up right. His computer is just telling him the wrong thing.
Old Mar 29, 2009
raygundan's Avatar
Problem solved. It appears that Bosch part #13680 will work, and has been chugging along all day today. It was $170 at autozone. Which is nice-- no waiting for parts to arrive, and local return if I should need it again. Autozone and friends seem to have the wrong thing in their system for the '01 HX... but it's correct for the '02 HX.
Thanks to all who offered advice-- you were a huge help, and saved me more than $200 off what the dealership wanted ($350 for the part, $50 for labor, and a mystery number for diagnosis).
Old Mar 29, 2009
04 Honda Civic's Avatar
yea you couldnt have plugged in a non heated O2 sensor since the connectors wouldnt match up anyway..good to hear its fixed though
Old May 15, 2009
astr033's Avatar
astr033 is an unknown quantity at this point
I just found your post. I have a 2001 Civic HX CVT too with the same error code (P1167). My upstream o2 sensor was replaced last August but didn't fix the problem. Just now I'm realizing that I need a wideband sensor. Seems it's more than just Autozone getting it wrong. The Parts Finder on the Bosch website does the same thing. It lists a wideband for the '02 HX but not for the '01 HX.
How is the Bosch 13680 wide band sensor working for you? I want to make sure that the check engine light never came back on. Seems the Denso version is a good deal more expensive, so it looks like I'll opt for the Bosch unless the Denso is highly recommended.
Thanks!
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
liljoe
Nov 4, 2001 01:27 PM
