What is wrong with my car??? Need help!
Old Feb 16, 2009
MOJO2509's Avatar
MOJO2509 is an unknown quantity at this point
Ok, I have few major problems with my '02 civic dx. First of all, every time I drive over bump or small road imperfection, front wheels start to either shake or vibrate. I went to few shops for the last 3 months. Nobody can tell me whats wrong. " everything looks good, we didn't find any problems". bullshit. Second, I noticed knocking sound today in the front end when I accelerate or drive at >40mph. Engine? May be there is any connection with first problem? Last one (which is more annoying than serious I guess) is that I hear clunking every time I drive over bumps. I guess I need to change my struts?
Oh, and there are 66k miles on it
Old Feb 16, 2009
MOJO2509's Avatar
Re: What is wrong with my car??? Need help!
I guess I will have to ask on other forums. Thanks for reading.
Old Feb 16, 2009
DDragon7's Avatar
I got a feeling that you have bad struts. My car was doing the same clunk when I drove over a bump before I got new Tokico HP shocks. Also could be a weak end link. I know I have a weak end link in the front, but it didnt make any more sound when I got the new shocks.
Old Feb 16, 2009
MOJO2509's Avatar
What about the knocking noise when I accelerate or drive at high speed? Engine problem? Timing belt? No "check engine" appeared. Oil level is normal. What could it be?
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
popping is your upper spring mounts, clunking over bumps is your struts, i recomend 4 new.
cluncking on acceleration is your front and/or rear motor mounts just look at them, they are broke. replace both or all 4.
Old Feb 28, 2009
you should get the whole suspension checked, something prolly is loose, aside from the bad shocks.
Old Mar 8, 2009
MOJO2509's Avatar
I went to the shop couple days ago and they found out that sway bar link is a little bit lose. This, they said, it could cause vibration and even a clunking noise. $88(sic!) to adjust it. Could it be the reason? I don't really want to waste money..THanks!
mikemc422
Aug 9, 2018 05:41 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
GH04si
Apr 15, 2015 08:13 PM
BREADFAN
Apr 15, 2015 08:58 AM
ImmortalEX
Oct 31, 2001 10:00 PM
