Trunk Vent
Old Feb 11, 2009
eyeheartvtec's Avatar
eyeheartvtec is on a distinguished road
Trunk Vent
Hola all, so after a couple replacements and finally giving up on them i duct taped it shut. but after a while it started leakin water into my trunk... again...
post your solutions to closing the vent! im looking for a more permanent solution to this other than duct taping.
Old Feb 12, 2009
Re: Trunk Vent
usually the car audio guys use dynamat, but be sure to prep the surface clean first and use a heat gun and roller to make sure you get a good bond. use overlapping pieces. like cover it with a small piece, then put a bigger piece. you can even put dynamat from the outside too. that stuff is like tar and will never leak water. other than that the only other foolproof solution is find a piece of thin metal (stainless steel) and sand the edges down to make it rough. then also sand the area of the trunk metal surrounding where the metal plate will go. buy some metal epoxy putty and use it to glue the metal plate over the hole. make sure you do the sanding, cause the epoxy doesnt stick too well to smooth surfaces. that will never come apart anymore. once the epoxy sets, spray the exterior side of the metal plate with a few coats of rubberized undercoating.
Old Feb 12, 2009
Re: Trunk Vent
sounds good. i got a load of extra dynamat lying around the house so ill try that first. if not ill probably end up welding it
solarpunk70
Apr 12, 2016 11:43 AM
Crazygrlinak
Oct 8, 2015 05:06 PM
senicalj4579
Oct 2, 2015 10:03 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
