2001 (2001-2005) 1.6 vtec manual making a click sound once when moving forward
Old Feb 8, 2009
maxim123's Avatar
maxim123 is an unknown quantity at this point
i have a 2001 (2001-2005 series) 1.6 vtec civic se manual (UK model). When I engage it in first gear and release clutch there is a click sound that comes from under the stering. the sound only comes once when moving forward from stationary and not when changing gears in the moving car.
the click sound comes just once when i engage the car in first gear and release the clutch. and not when i move into other gears. the car has just 26k miles on the odometer.
Thanks and regards,
Maxim
Old Feb 8, 2009
nosupra's Avatar
nosupra is an unknown quantity at this point
Re: 2001 (2001-2005) 1.6 vtec manual making a click sound once when moving forward
It kinda sounds like its the throw out bearing. I had min replaced because of that
Old Feb 9, 2009
maxim123's Avatar
r u sure as the clutch is fine??? its a click sound when the car moves forward and comes once and not when in 3rd 4th or 5th gear.
Old Feb 17, 2009
Tomj333_EM2's Avatar
Tomj333_EM2 is an unknown quantity at this point
Its like a spring realising.... mine does this only after moving off for the first time after car has been stood switched off.
I dont think its a problem myself... everything sounds fine no noise 82k....
Old Feb 17, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Same thing here, I find it's when I go from reverse to forward, I can get it to happen over and over and over like something is popping backwards, then forwards, then back....
Old Feb 17, 2009
maxim123's Avatar
maybe thats it then. like i said only comes when the car moves forwad from stationary and not when reversing. its not clutch spring as pressing and releasing the clutch in neutral doesnt create the noise. it also comes sometimes when moving from 1st to 2nd but not when moving into 3, 4 , or 5th gear.
Reagrds,
Maxim
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Dorval Andre
May 1, 2015 09:37 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
cooldan1
Apr 23, 2015 10:49 AM
CapYoda
Nov 11, 2001 05:17 PM
