2nd and 4th gear issues
Old Feb 5, 2009
joe_honda's Avatar
joe_honda is an unknown quantity at this point
I have a weird problem and im hoping someone here can point me in the right direction as to what this could be, but here is what is happening:
At any speed, regardless if the engine is running or not, going from 1st to 2nd is really "stiff", almost as if the shifter is clogged with gum or something. Going from 3rd to 4th is exactly the same, however if i back out of 2nd or 4th into nuetral and then go back in gear its perfectly fine. Now when i put it in 3rd i hear a squeaking sound (like a rusty door hinge or something) and it seems to emit from the shifter itself (not the tranny).
I never seemed to have this issue until the temps here started getting into single digits.
Does anyone know what could possibly be causing this issue?? I've literally been skipping these gears when driving because its such a pain in the butt.
Thanks!
edit: this is an 02' EX coupe with 108k miles
Old Feb 9, 2009
joe_honda's Avatar
Re: 2nd and 4th gear issues
Now that the temps have gone up 40F+ this doesn't seem to be much of an issue anymore.
Wonder what it is about the cold it doesn't like....
Old Feb 9, 2009
Zzyzx's Avatar
Autocross Junky
old & thick Transmission fluid + possibly worn synchros. Does double clutching make it go in to gear smoother? if it does, then its most likely a worn synchro issue.
Old Feb 10, 2009
joe_honda's Avatar
Nope, in fact i can have the car completely off and not clutch at all and it will do it.
On my drive home tonight i didn't have any issues whatsoever, its the cold that triggers it. I had my tranny fluid changed 8000 miles ago as well.
Old Feb 16, 2009
R8DERCV's Avatar
R8DERCV is an unknown quantity at this point
Hey Joe, my civ does it too. I had my clutch replaced and it still does it, i think it's just the cold.
Marcus2thextrem
May 10, 2015 03:08 PM
Jeeves
Transmission
Jan 31, 2002 08:37 AM
conspiracy90
Jan 19, 2002 08:37 PM
conspiracy90
Jan 19, 2002 03:21 AM
Russps
Nov 8, 2001 02:00 AM
