headlights not aligned?
Old Feb 2, 2009
ABS929CBRRR's Avatar
ABS929CBRRR is an unknown quantity at this point
put HIDs in this weekend. took it out at night and somthings off i am guessing. my left side seems to shine normal height but the right side seems to shine lower towards the ground. both headlights are mounted up correctly and i took everything appart 2 times to check.
any ideas? it bugging the heck outta me. if i crawl up somones bumper only the left shines on the persones bumper in front of me and the right is def shining a good counpleof inches lower. my bumper lines up correctly also...im so confused.
.....??????? anyone run into the same problem?
Old Feb 2, 2009
Re: headlights not aligned?
well anytime you change the bulbs, you can lose alignment. park next to a white wall about 25 ft away and adjust them. theres a gear in the back you can turn with philips screwdriver to move them up and down.
Old Feb 2, 2009
Hey thanks so much, i know nothing about car so ill check it out tonight. Im a sportbike guy haha. my garage is all white so ill try that trick.
Old Feb 2, 2009
if its stock oem lights, it is easy to do, but if they are aftermarket projector, you have to remove them to reach the bolt in the back.
Old Feb 2, 2009
they are aftermarket stock looking lights. blacked out jdm ones but look 100% oem
do i need to remove bumper and grill and lights to find this screw? i got my OEM lights at my house yet so maybe i can find it on there, where ever its located.
Old Feb 2, 2009
no. just look above the headlight and you will see the gear. there is a hole in the frame i think to stick the screwdriver to reach it. you cant miss it if you look down in the back of the light.
Old Feb 2, 2009
i found it, thanks!
Old Feb 3, 2009
got them lined up verticaly....but they seem a tad bit off to the right both of them. is there somthing to line them up horizontaly?
Old Feb 3, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You don't want to line them up horizontally, cars in North America have their headlights tilted that way to stay out of other drivers' eyes. If you've ever seen a JDM car (piles and piles of them here), you'll notice they have theirs tilted to the left and blind everyone in the oncoming lane.
Old Feb 3, 2009
ok that works, i didnt know. i never noticed it on the oem lights cuz they were not as bright as mt 10000K HIDS.
thanks for explaning.
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
