I cant figureout whats wrong
Old Jan 21, 2009
Topgeari4's Avatar
Topgeari4 is an unknown quantity at this point
hey guys i have a 2002 honda civic lx coupe
i just got all new tires from pepboys 2 weeks ago
right away i noticed when i drove the car between 50-60mph it would vibrate then be fine once i went faster until i got to about 80
someone backed up into my passenger side and cracked my wheelcover, threw my alignment off and damaged my fender and apart of the door
so i went back to pepboys and got my alignment done, when he was doing this he told my that my front passenger side strut was bent and that it should be replaced
now when i take my car about like 70mph it starts to vibrate
my car only has 23k miles on it
so should i get the tires rebalanced and change the front struts ?
also at what speed does ur civic vibrate if it does at all ( my car is stock )
thanks guys i need to figure out whats wrong ASAP
Old Jan 21, 2009
greeen01civic4d's Avatar
Re: I cant figureout whats wrong
first off, balance tires, if bent strut, replace it. then come back if u still have problems
Old Jan 21, 2009
D16Fiend's Avatar
D16Fiend is an unknown quantity at this point
strut then alignment. immediately
Old Jan 21, 2009
Topgeari4's Avatar
should i replace both front struts or just the bent one ?
Old Jan 21, 2009
always in pairs alignment wont fix a vibrating tire, unless the toe is severly out. please, please save ur money and have tires balanced first
Old Jan 21, 2009
Topgeari4's Avatar
ok ill go to another place and have them re balance the tires
but cant they use a machine to see if the balancing is off ?
Old Jan 22, 2009
TRIZ's Avatar
They use a machine to balance the tires. Then they probably use a machine to do the alignment as well. Machines own.
Old Jan 22, 2009
Topgeari4's Avatar
ok i found the alignment report he gave me and the toe he was able to fix but the camber on the drivers side is -0.7 and the passenger side ( the side that got hit ) is -1.5
today i will take my car to another tire place and have them check the balancing and if its off to have that redone
Old Jan 22, 2009
u might not be able to fix the camber without a camber kit. but camber is not gonna affect shaking tho. have the tires "road force balanced" and u will get an answer quickly, trust me
Old Jan 22, 2009
Topgeari4's Avatar
what is " road force balanced " ??
but wouldnt i need a camber kit if i had like switched my wheels for a bigger size ?
how fast can you go in a stock civic before it starts to vibrate ?
Old Jan 22, 2009
its not about speed, its about balance. and a road force balancer is a type of balancer, it meaures forces put on the tire, and pull, and balances better
Old Jan 22, 2009
Topgeari4's Avatar
ahh i c
so where can i go to have them road force balanced ?
Old Jan 22, 2009
call around to local shops, and ask if they have a road force balancer
Old Jan 25, 2009
Topgeari4's Avatar
hey ok
so i got them rebalanced and the guy at this shop said that one of the rear wheels had too much weight for balancing, but once he did it it was less then before but still more then other 3 but he said the rim isnt bent or anything?
so now when i take the car up to speed it doesnt vibrate as much as before
but SOMEtimes when u accelerate slowly from like 50 to 60 it will
so should i change the front 2 struts now ?
Old Jan 25, 2009
MidnightCivic's Avatar
did you check your tires? i had the same issue and it ended up being a bad tire..
Old Jan 25, 2009
Topgeari4's Avatar
how do i check to see if its a bad tire ?
Old Jan 27, 2009
Topgeari4's Avatar
anyone know ?
how do i know if its a bad tire ?
Old Jan 27, 2009
Alpha 5's Avatar
When the guy rebalanced the tires did he use a road force balancer or was it a stupid spin balance job?
If you had them road forced the machine would have told you the tire is bad....
Old Jan 27, 2009
thank you matt, noone listens to me
Old Jan 28, 2009
Topgeari4's Avatar
yea he used the road force balancer and he let me stand next to him and he told me that the previous guy had put too much weight on to balance the tire. then he told me the same thing that its most likey the front strut because its bent
Old Jan 29, 2009
Alpha 5's Avatar
A bent strut will not cause you to vibrate a diff speeds.
Do this.
Take your rear wheels and put them on the front, take your front and put them on the rear.
Now go drive the car. Tell me if it still vibrates as much and if the vibration is coming from the same location as before.....
I bet that if it is vibrating in the front now, after you move the tires it will be vibrating from the rear.
Now go prove me wrong.
Old Feb 3, 2009
Topgeari4's Avatar
hm yea it was comming from the back now its in the front
should i put the spare tire on to see which rim / tire is causing the vibration ?
Old Feb 3, 2009
Alpha 5's Avatar
You have had the problem a week and you still don't even know which tire it is?????
Old Feb 4, 2009
Topgeari4's Avatar
nah bro my car was at the body shop
Old Feb 10, 2009
Topgeari4's Avatar
ok i got the tire road forced balanced from the local honda dealer and he said that one of the rims is bent.
he lowered the air pressure to 28psi for each tire and he put all the weights on the inside
now the hunt begins for a steely on cl lol
Old Feb 10, 2009
told u it would figure it out for u
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
