Battery Light Flickering?
Old Dec 29, 2008
lovemyciv's Avatar
lovemyciv is an unknown quantity at this point
Hi. I have a 02 civic. I just had the head gasket, timing belt, water pump, radiator, and power steering belt replaced. It is at about 115k miles. Yesterday, while driving my car I noticed that the battery indicator on my dashboard was faintly flashing very fast. If I went really fast around 75/80mph it stopped. Any idea what this could be?
Old Dec 29, 2008
Re: Battery Light Flickering?
problem with the charging system. either your alternator belt is loose, your battery terminal connections are loose, or your alternator is dying.
Old Dec 29, 2008
popee's Avatar
popee will become famous soon enough
^^^^ i had the same problem .. had to replace my alternator,
Old Dec 29, 2008
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
I had the same problem minus the 75-80mph bit. My alt was bad. I had to replace it twice.
Old Dec 29, 2008
natey57's Avatar
natey57 is an unknown quantity at this point
a bad alt. can also cause srs light to come on and not set any dtc's (alt will put out ~16v, and srs control unit goes into fail safe mode) ....but yeah - probably bad alternator!
Old Jan 24, 2009
gh0st's Avatar
TAQUITOS!!!!
Sounds like my symptoms. Had my SRS and ABS light come on and off. They would go away with the rear defroster, fog lights and/or fan blowing full blast.
Finally the battery light would come on and eventually after getting a jump from AAA, all the gauges turned off, the radio shut down and my headlights turned off. Towed it home and now it sits. Gonna test the alternator, thankfully a lifetime warranty one, battery has a warranty too. Must've been a bad alt, cuz I just replaced it January of 08.
beantech
Jun 15, 2015 07:09 PM
HiImBrandon
Jun 1, 2015 07:34 AM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
