OBD II code P1258 my converter?
Old Dec 2, 2008
BoomerXx21's Avatar
BoomerXx21 is an unknown quantity at this point
Sooo I dropped two OBD II codes after my engine was swapped for another d17a2. popped up a P1258 "VTEC system malfunction" with causes being low oil/pressure; blocked oil passage; or failed vct oil control valve. now the guy at my local speed shop had another d17a2 blow rings just like mine and apparently the burnt oil and everything in the exhaust messed with the catalytic converter and the 02 sensor and he dropped codes also, just replaced those two things and was all good. The other code i dropped was unrelated I think, P0505, PCM has determined that a malfunction exists in the idle control system. I had the engine swapped out so my guess is bubbles in the coolant. If anyone could tell me the actual problem on the P1258 code or any educated guesses on what would cause that code, keeping in mind i blew the engine and burnt shitloads of oil and had an engine swap done.
Thanks a bunch,
Brian.
Civic15
18
Sep 19, 2017 07:48 PM
beeemerdude
Jul 10, 2015 09:22 PM
