2001 Civic Loud Engine Noise
Old Nov 28, 2008
JAQUEBAUER's Avatar
JAQUEBAUER is an unknown quantity at this point
Smile 2001 Civic Loud Engine Noise
jaqueobauer@gmail.com
Engine Mechanical problem
2001 Honda Civic 4 cyl Two Wheel Drive Automatic 110000 miles
HAS 110 K MILES
HAD TIMING BELT REPLACED AT 60 K AS PM
LOUD NOISE COMING FROM INSIDE ENGINE FRONT
LIKE ITS UNDER TIMING BELT COVER
ITS A GRINDING / RAPID CLICKING NOISE
ENGINE WILL RUN, IT DID NOT STALL OR FAULT
NO ENGINE FAULT LIGHTS
NO METAL IN OIL---AS OBSERVED ON DIPSTICK.
CAR WAS SHUTDOWN AND TOWED HOME.
I NEED TO GET AN IDEA OF WHAT MIGHT HAVE FAILED....TENSIONER, OIL PUMP ????
PLEASE HELP....ITS MY DAUGHTERS CAR.. THANKKS VERY MUCH
Old Nov 28, 2008
Re: 2001 Civic Loud Engine Noise
has it ever had a valve adjustment? maybe take off the timing cover too and see if anything is rubbing with the cam gear.
Old Nov 28, 2008
CraigW's Avatar
Some of the other items that would be due at 110k may be failing if they were not replaced at 60k (tensioner,water pump etc)
I always thought the cycle for for this series was 110k ??
Old Nov 29, 2008
JAQUEBAUER's Avatar
Thankd for the reply. At 60 k had the timing belt, water pump, tensioner ( The Honda reccomended timing belt work) replaced by Honda. The irony is that we were shopping for a replacement car at the time of failure. I am going to pull the top timing cover today and eyeball things.
Again, thanks all for the rapid responses.
Old Nov 29, 2008
JAQUEBAUER's Avatar
Thanks for the reply. At 60 k had the timing belt, water pump, tensioner ( The Honda reccomended timing belt work) replaced by Honda. The irony is that we were shopping for a replacement car at the time of failure. I am going to pull the top timing cover today and eyeball things.
Ans yes, its due for timing belt replacement agaain at about now.
Old Dec 3, 2008
micheecivic's Avatar
micheecivic is an unknown quantity at this point
If you have not found the problem yet then you should check the tensior for the belt. Not the one for the timing belt just the outer one near the bottom of the motor these fail alot, and give a grinding and somtimes either ticking or scraping noise like thin metal scraping. All you have to do is take off the belt and spin the tensior you will know is its that. i think its a 14 for the pully bolt and a 12 for the tension bolt.
mattdoc
Mar 14, 2017 12:10 PM
ashleymmackey
Apr 18, 2015 09:48 PM
smmahan
Apr 15, 2015 08:17 PM
liljoe
Nov 4, 2001 01:27 PM
