02 civic tranny issue
Old Nov 13, 2008
THECHRIS's Avatar
THECHRIS is an unknown quantity at this point
so i have a 2002 civic coupe. ex i believe bought not sure and a 5 spd. i bought the car from my parents just so i could have a car. i learned to drive standard on it as well as my older brother. so there was a point the clutch wasn't treated the best. but for the past year theres been no grinding or dropping. then about a month ago i realized then shifting into 3rd has become horrid.
if i shift into 3rd casualy then theres no problems.
but when i shift quickly/more aggressivly, it sound and feels as if its grinding through. feels disgusting.
has nothing to do with how i press in the clutch. it's always to the floor. even if i'm just parked, i push in the clutch, and as i shift to 3rd gear with any quickness, it grinds.
i don't exactly know why, but i would like to fix this problem at some point.
thanks in advance
chris
Old Nov 13, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: 02 civic tranny issue
if your parked and u shif yes it's expected to grind a little. the gears are spinning still after u push in the clutch.
i started having the 3rd gear grind. i changed the trany fluid and that has fixed it so far. no more grinding yet.
make sure u put in honda manual trany fluid or MTF. dont get gear oil. this will help out bigtime. (at least it did for me)
EDIT woo 300th post
Old Nov 18, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
Sort of same issue with my 01 civic 5spd its a very slight crunching or clicking feeling in 2nd gear for me. Ill try changing fluid but dotn think it will help
Old Nov 29, 2008
Deepa's Avatar
Deepa is an unknown quantity at this point
Try a synthetic fluid, I've had issues with other cars in the past, synthetic won't 'fix' the problem, but it will make it much better. It might take a few days of normal driving to notice a difference.
Old Dec 2, 2008
Protan988's Avatar
News flash. You can only use Honda manual transmission fluid unless you want to screw up your tranny more, and you cant get in in synthetic.
Old Dec 2, 2008
Protan988's Avatar
Btw I changed my tranny fluid today. So far nothing has changed.
Old Dec 2, 2008
lordhelmet's Avatar
Its going to be your third gear syncro thats the problem.
Old Dec 4, 2008
Superjester's Avatar
Superjester has a spectacular aura aboutSuperjester has a spectacular aura about
Sounds like the Brassbearing.
Either way. Try changing your oil. If that doens't work. Drop the Tranny. If it's too much for you to take a peek inside. Get a used Tranny and replace it.
I swear. What was honda thinking in these years? We have to have the worst transmission ever!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
civic_gt
Apr 19, 2015 08:15 AM
skywalker
Nov 8, 2001 05:04 PM
