hot and then cold.
Old Nov 25, 2008
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Question hot and then cold.
okay 7th gen ex is what im driving. About a month ago I was driving along and when I came to a stop light I realized my temp was rising. So I drove to the nearest parking lot and the temp went back to normal. I figured the thermostat probably just got a little stuck and didnt give it another thought. Since then its gotten cold and ive been using the heat, but it fluctuates between hot and cold. Only when I give it a good dose of pedal to the floor does it start to heat up again. Now I know that the temp could be a sign of a waning thermostat, but if it isnt overheating and the heat is fluctuating, am I looking at the same sign? Could it be a heater core issue? I hope it is just a thermostat! Hit me up let me know what you all think.
Old Nov 26, 2008
GreenFamily's Avatar
GreenFamily is an unknown quantity at this point
Lightbulb Re: hot and then cold.
Have you checked to make sure your coolant is full?
Check both the reservoir and the radiator.
It is not uncommon for you to loose heat and see the engine temp rise at low RPMs while returning to normal at higher RPMs when your cooling system is low.
Old Nov 26, 2008
mr22508's Avatar
Yeah I checked it, but come to find out it WAS the thermostat. I decided to go ahead and change it and now my heat is kicking like a Arizona summer wind storm!
solarpunk70
Apr 12, 2016 11:43 AM
jtcavey
Sep 30, 2015 02:18 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bruce2
Sep 21, 2015 08:01 PM
