DRL Lights
Old Oct 10, 2008
Matias's Avatar
Matias is an unknown quantity at this point
DRL Lights
so I've got a 2002 Civic LX, the DRL light goes off and on rapidly and there is a buzzing noise. The right front DRL light is also out. I checked some other topics, but there didn't seem to be a fix.
If i just change the DRL bulb will it fix it? or is it buzzing because of a problem with the DRL fuse or something?
Also, CD player won't eject. Anything I can do other than try to pull the disc out with plyers?
Old Oct 10, 2008
Re: DRL Lights
change bulb first, if still buzzing, could be the relays or the module (behind hood release panel). cd player is common problem, just throw away and get another one off ebay. or aftermarket even better.
Old Oct 12, 2008
DDragon7's Avatar
Re: DRL Lights
If the buzzing noise goes away when you turn on your lights, then its a DRL relay problem. I'd just disable the DRL, it would be cheaper than replacing the relay.
Old Oct 13, 2008
Matias's Avatar
Re: DRL Lights
hmm, ok...because the right headlight works when I turn the lights on, just not the DLR one.
How much are the relays anyways?
Old Oct 13, 2008
CraigW's Avatar
Re: DRL Lights
Is the buzzing coming from drivers side area ??
Some have said that the DRL control module can be repaired (the buzzing anyhow) by re-soldering the leads on the relay located inside the control unit on the circuit board. At one time there were pictures posted somewhere.
Old Oct 13, 2008
DDragon7's Avatar
Re: DRL Lights
I cant remember how much it was, but it was either close to or over $100 CDN.
Here is the post that I found earlier, but never attempted to do that may fix the problem, https://www.civicforums.com/forums/2...ewed-am-i.html
Old Oct 17, 2008
Matias's Avatar
Re: DRL Lights
yea, drivers side.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
eorlando1
May 17, 2015 11:16 AM
davidarenberg
May 16, 2015 08:45 AM
