Type R grill install = unwanted gap
Old Sep 30, 2008
greenbay0405's Avatar
greenbay0405 is an unknown quantity at this point
So... I gave in to the aftermarket grill trend and bought one of those $30 type r grills off of ebay. Now my factory "radiator cover" (or piece of gray plastic attatched to my stock grill) won't go on the aftermarket grill, which gives me a nice little gap between my grill and my hood . I own a 02 civic ex coupe. Anyone know where I can get one of these bad boys that will fix the gap? Also, I can't get my bumper back on as snug as it was (just a little loose around the right headlight). Is this just a side affect of taking it off? Thanks for all the help in advance!
Old Sep 30, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: Type R grill install = unwanted gap
No it is not a side effect of you taking it off, it just means you did something wrong and most likely didnt snap the bumper into place. I say just give it a firm tap and see if it pops back in.
I believe that the Type r grille leaves a nice gap between the hood and grille. Just search on this site for pictures to see if everyone else has the same thing, if not try a little ingenuity and fix it.
Old Sep 30, 2008
DDragon7's Avatar
I've heard that the sedan rad cover will go over that grill and it will take away that unwanted gap.
Old Sep 30, 2008
I've heard that too, but I can't find one. Anyone know where to find this part?
Old Sep 30, 2008
popee's Avatar
popee will become famous soon enough
Yes the sedans rad cover fits,, not the coupes, you gotta go to the dealer or even a junk yard to find the rad cover
Old Sep 30, 2008
the grill was made for a sedan, reason being my radiator cover fit perfectly with the new grill. the fix for coupes is easy, just buy the sedan radiator cover
also yes, there will be some gap between the grill and hood as mentioned. that is normal part of the grill design.
for the cover, you need to get #2 here. when you order it from dealer or www.hondaautomotiveparts.com that you make sure its for sedan.
Old Oct 1, 2008
Thanks gearbox, its ordered and on its way! If I understood you correctly, there will still be a gap, right? Does the radiator cover make it look any better? And how did you keep your emblem on there???
1.7ali
Sep 6, 2015 07:36 AM
sjonesd3
Jun 11, 2015 06:32 PM
carid
Jun 10, 2015 09:57 AM
ScottyEj8_DB7
Apr 26, 2015 04:07 PM
