HELP! Cranking issues...and low idle issues!
Old Sep 18, 2008
dougjr99's Avatar
dougjr99 is an unknown quantity at this point
I have two problems, and they both started at the same time, so I am assuming for now they are related.
1.)The other morning I tried to crank my 2000 honda civic ex w/auto trans.
It just barely would turn over. I thought I might have left something on, but I checked immediately, and nothing was left on. I popped the hood, checked the cables, looked fine, no corrosion. Turned over the ignition again, and it finally started. Since then, it seems to crank faster the more I hold the ignition in 'crank' mode.
2.) After that first morning, it seems to want to drop it's idle (down to almost nothing) when the engine gets warmed up, particularly when I'm at a stop light in Drive. I put it in Park, and it may idle back up to around 500 rpm, or it may not.
Like I said above, I'm sure these problems are related.
Is there anyone that knows what's going on?
2000 Honda Civic EX. AT. 77K miles
Allecr3
May 22, 2015 01:24 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
