2001 Auto Limped to the Driveway
Old Sep 1, 2008
earl610's Avatar
earl610 is an unknown quantity at this point
Overview
Let's talk real fixes for these stupid automatic transmissions. I'll give some background and I'd really like to hear any ideas you may have. Or jokes. Or the number for HondaAmerica.
Background
Ok, 125K. My auto started whining about 2 weeks ago, check engine light lit up 2 days ago, auto slipping yesterday, and it limped home - barely - a few minutes ago - it'll take a tow to get out of here.
I read all morning about the various whines that these suckers have. In addition to the transmission whine (probably the 2nd transmission based upon what I've read), there is at least one belt whining (tightened one yesterday to specs), PS whine (topped off the fluid), and the stereo speaker whine that goes with the RPM (became a lesser concern lately.
Alternatives
First - high performance upgrade to solve problem. Anyone got something? Shops in sacramento CA with experience?
Second - auto to manual swap? Never should have bought an automatic, but I didn't think I'd fit in the car well with a manual (tall).
Third - Next time, how about a Honda synthetic AT Fluid? Something else? Do they even make that?
Fourth - Replacement options? Rebuilt unit? Shops in Sacramento?
Fifth - Could the slipping be anything else?
Sixth - Should I fix and sell this lime?
Old Sep 2, 2008
earl610's Avatar
Re: 2001 Auto Limped to the Driveway
Local dealer indicated that extended warranties / recalls were offered on Accords and Odysseys but not the Civic. Great. Gave him my VIN and he called back with a $2495 quote. Not bad. 3/36000. Not as good as free or $1000 but it's a start right?
Old Sep 2, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
First thing you're gonna wanna do is diagnose that check engine light. You can then determine the severity of the problem.
Old Sep 2, 2008
greeen01civic4d's Avatar
agreed, most likely its slipping clutches inside the trans, between gears, prolly 2-3 maybe 1-2, there are rebuild kits, there are performance kits, tougher clutches adn whatnot, but again, require a rebuild. u can however, get a low mileage auto trans from a junkyard for cheap, and a manual trans will last much longer
Old Sep 3, 2008
TCI master racing overhaul kit. comes with a ton of stuff including new clutches. have a shop rebuild yours. im sure its the second clutch thats defective like all the other problem cases. honda has a tsb on it now, ofcourse that doesnt help anyone since all those 01-02 are out of warranty lol. honda ATF is still the best fluid ive used for this trans. its not the fluid in this case tho, its an actual defect in workmanship in the trans (secondary clutch pack). not sure if they fixed it for 04-05 models or not. auto trans on my 02 civic started slipping at 50k miles. ive been using lubecontrol lc20 in the fluid, as well as added an HX civic trans fluid filter and a trans fluid cooler from B&M, im at 80k now and it did not get any worse. im trying to make it last as long as possible before rebuild.
Old Sep 3, 2008
dcjose20's Avatar
dcjose20 is an unknown quantity at this point
if you want to take the route of getting a low mileage transmission from a junk yard, see if you can find one from an 05 model. I was assured by ppl on this forum that this was a possible course of action because 05 transmissions were compatible with the 01 year my car was. I haven't had a problem with the transmission since.
sharp66
31
Jun 12, 2022 08:45 AM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Dangerousjordan
Jul 23, 2015 11:11 AM
Khmi
Jun 23, 2015 11:03 PM
McD
Apr 16, 2015 10:46 AM
