Engine Side Mounting Rubber
Old Aug 27, 2008
itchoy's Avatar
itchoy will become famous soon enough
guys i need help....my engine side mount rubber got busted....half of the rubber was falling off already and the engine starts to shake really bad....
its the one on number 6
can i change this my self if i have the right tool? i think all i need is a wrench an a jack right? put me in the right direction guys
thanks
Old Aug 27, 2008
itchoy's Avatar
Re: Engine Side Mounting Rubber
bump
Old Aug 27, 2008
speedfoos's Avatar
Can't see your pics but that mount is really easy to remove. Do you have and EX or LX? The LX is easier because there is no ABS module in the way.
That being said, all you need is a 10, 14, 17, and 19mm deep well socket to get the mount off. Eyger just did this. You don't even need to jack up the motor. Should only take about 45 minutes to replace it.
Old Aug 27, 2008
speedfoos's Avatar
Sorry, the 10mm is to move the ABS module out of the way if you have it.
17 and 19mm are to take the actual motor mount bracket off. Once that is off, you use the 14mm socket to remove the three bolts which hold the mount to the frame. Too easy.
Old Aug 27, 2008
itchoy's Avatar
thanks man...all i need to do i order the mount
Old Aug 27, 2008
speedfoos's Avatar
Yep!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
silverhx
Nov 14, 2001 07:04 PM
