help no ac
help no ac
need help guys, on the way to work this morning had ac on dial on like 3 arr work cut the ac off no problems, got in this evening to go home cranked up car then cut ac on, no ac switched to hot, get hot air but fan is not blowing, is there a fuse or switch, thinking a fuse may have blown, diagram of fuse box? anyone have diagram or no whats going on, is like 100+ degrees man need some ac bad!
Re: help no ac
what fan, the ones by the radiator, or the actual blower in the car? if no air blows through the vents, your blower motor is prolly bad. does the ac compressor turn on when you press the ac button?
