Weatherstripping Help?
Old Jun 25, 2008
breault5's Avatar
breault5 is an unknown quantity at this point
Question Weatherstripping Help?
i have an 02 coupe and it whisltes pretty bad inside coming from the front of the roof...i believe the whislte is from the weatherstripping being worn from the blazing sun here in Socal cause the weatherstripping gets hot and just becomes really flexible and loose so i think i want to change the weatherstripping where the windshield and the roof meet at the top and also change the weatherstripping around my sunroof....
so.... how do i replace those weatherstripping does it just come off by pulling on it?? and to put it back on do i use any kind of sealant or anything to help it stick??
Replies would be appreciated!! Thanks
Old Jun 26, 2008
breault5's Avatar
Re: Weatherstripping Help?
bump/...please
Old Jun 26, 2008
CraigW's Avatar
You could try temporary wide masking tape over the entire top strip to see if the wind noise goes away and narrow down the source.
I just had my windshield replaced and they install a new top moulding, It is possible it may be a one use item.
The makeshift parts manual I have shows the strip at around $12-15 The seals for the sunroof seem more complex (many small seals)
Old Jun 26, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Ideally you can just pull it out
Though I think you should make sure that is your problem before you attack the sunroof. You don't want to find out its just a whistling noise coming from your nose, or from the glove box.
Old Jun 26, 2008
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
theres a tsb on this...not much u can do but replace it...
Old Jun 26, 2008
breault5's Avatar
okay thanks guys that actually sounds like a good idea( the masking tape)....is the tsb still active???
Old Jun 26, 2008
greeen01civic4d's Avatar
tsbs dont go inactive, they are just diagnostic tools, there is no way honda would cover this under warranty past 36k
Old Jun 26, 2008
breault5's Avatar
oh okay i just thought since the word temporary was in tsb i figured they expire...but yeah 36k, im pretty far past that haha, but am i the only one having this problem???
Old Jun 26, 2008
where is the word temporary in technical service bulletin? no ur not the only one, i have the same thing on teh passenger door on my 02 em2
Old Jun 26, 2008
breault5's Avatar
ohh haha i thought it was temporary service bulletin haha my bad haha
thanks for the replies ill see about the masking tape tomorrow!
Old Jun 27, 2008
lol, no biggie, try out the masking tape, then ill help u after that, ive got some ways to seal windows adn stuff, but gotta be careful
Old Jul 6, 2008
breault5's Avatar
hey so ive finally did it and yeah thats definatly the problem so help with the sealing???
Old Jul 6, 2008
so where was it leaking from? the sunroof or teh windsheild?
Old Jul 6, 2008
breault5's Avatar
the windshield weatherstripping..
Old Jul 6, 2008
u can try using weatherstripping sealant, comes in a tube like silicon caulk, and have to use the same gun, but if it doesnt work, ull have to get a whole new weatherstrip, have the windsheild pulled out and have it resealed by a professional, but if u do decide to use the sealant, use sparingly, and be careful, it makes one hell of a mess if u dont. all u have to do is peel back the current weatherstrip, and spread under it with the caulk gun, then press the weatherstrip back down
Old Jul 8, 2008
breault5's Avatar
alright thanks i think ill try that.. do you think you can find it at autozone or maybe a home depot or something is better???
Old Jul 8, 2008
id go to like napa honestly, they have the most chemicals and sealants, i wouldnt buy parts there, but sealants and chemicals yes. just ask for weatherstripping sealant
Old Jul 8, 2008
breault5's Avatar
okay thanks for the help i appreciate it and ill give you guys an update when i do it!!
Old Jul 8, 2008
sweet, good luck man, u need anything just ask
Old May 11, 2012
CIVIC05EX's Avatar
CIVIC05EX is an unknown quantity at this point
You sound good in finding and pointing to solution for the wind noise I hav in my car...
I can hear it right above my ears when i reach 40mph, couldn't find where is the leak... any suggestions?
thanks,
