Erratic Temp Guage....any advice
Old Jun 19, 2008
4bangin's Avatar
Need a little advice...driving home from work last night i noticed my temp guage was acting very erraticly.
It is an 02 Civic EX Coupe - 5-speed
I was driving about 35 mph for a good 10 miles then jumped on the interstate. I soon as I was on the interstate, my temp guage shot all the way up to H and stayed there for about 5 secs, then slowly went back down to the middle, or normal running temp. Every couple of miles (driving 60mph through construction zone) it would rise slowly to about 3/4 H and then slowly fall back to normal temp. This did this all the way home (about 25 miles). As i was almost home (driving 25mph through plan), it shot back up to H and slowly dropped down again.
It was completely normal driving to work today and I havent noticed any problems with how it is running. Engine does not seem overly hot and there are no fluids leaking from what i can see.
Any advice on what this may be? Could my thermostat be going bad or possibly the guage/wiring? Also, my check engine light has been on the last few days but i never really pay attention to it because it was contanstly going on and off when i had a high flow cat on there (the exhaust is now back to stock, as is the rest of the car) so i usually just ignore it and it goes away.
Old Jun 19, 2008
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
Re: Erratic Temp Guage....any advice
Could possibly be the head gasket. Take a look at the coolant levels. If it is low and you fill it up and a little later it is low again then the coolant could be leaking into the engine and burning up which wont show any leaks on the ground. I had this happen to me and was lucky to get it repaired by the powertrain warranty.
Old Jun 20, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
If you have a CEL, go to autozone, borrow a scanner and scan the codes. Anything not emissions related (or even anything recently emissions related) could be a pointer to the source of your troubles.
What you described could be a failing water pump, blown headgasket, air in your cooling system or a leaking heater core. How many miles on it, and has the timing belt / water pump been done?
if this happens again, turn your heater on full hot and full fan and see if you hear a running water type sound - that is air in your cooling system. If there's no running water sound and the temp goes to normal and stays there, it may be just a thermostat issue.
Good luck.
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
Bruce2
Sep 21, 2015 08:01 PM
srtlat
Sep 17, 2015 11:02 PM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 12:23 PM
