Timing Belt maintenance
Old Jun 18, 2008
Ford's Avatar
Ford will become famous soon enough
1111
Old Jun 18, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Re: Timing Belt maintenance
Check my Timing Belt DIY - link on the sig.
The parts kit looks fine as far as what you'd need, but I usually just buy from majestic honda to get OEM parts. I can't speak for the reliability of aftermarket parts, but others have used them.
You'll need a coolant drain plug washer and coolant if they will be doing a coolant flush (which they should).
Old Jun 19, 2008
Ford's Avatar
1111
Old Jun 19, 2008
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
How much mileage you have on the car? I am at 70k and just wondering when I should get this done?
Old Jun 20, 2008
pheaton's Avatar
A descendant of 2k1civic.com
I think the recommended mileage in the owner's manual is around 110k. I have about 85K and plan on doing it pretty soon. I don't like waiting that long. I'll do it this fall, or maybe next spring.
Old Jun 20, 2008
reddawnman's Avatar
I think it is also 6 years regardless of mileage, but I'd have to look it up.
I did mine at 104k. The thing that wears on the belt more than most things is extreme variations in temperature, moisture and extreme heat. If you live in the desert or make transits from dry, hot places to moist places (like a vegas to socal run), you might want to do the change earlier, but honestly I think 110K is a number that was arrived at with a decent safety margin already built into it.
Oil, coolant, or grime on the belt will also shorten the belt life, so if you've ever had a seeping valvecover or water pump, you might do the TB earlier. Again, I think that honda gives that 110K miles rating with a good margin of safety already built in.
Old Jun 20, 2008
greeen01civic4d's Avatar
standard service - 110k miles
extreme service(hard driving, hot to cold, stop and go, etc..) - 90k miles
use honda parts, from a dealer, period
u will need: timing belt, valve cover gasket, 1 gallon of coolant, water pump, tensioner(not necessary, your choice) crank pulley holder tool.
good luck, and search for diy, its not very hard, just time consuming
Old Jun 20, 2008
reddawnman's Avatar
You'll need slightly more than 1 gallon... and I mean just slightly, like .2 gals. Pissed me off I had to buy 2 gals for that little extra.
Thanks green for looking up the service specs, it's 109 in SoCal today and i didn't feel like doing anything except going to the pool.
Yeah, timing diy, just click on my sig link.
mattdoc
Mar 14, 2017 12:10 PM
ChristinaVHH
May 10, 2015 03:51 PM
markp94
Apr 30, 2015 09:19 PM
rcolosi
Apr 29, 2015 07:48 PM
bsmiley
Apr 27, 2015 01:27 PM
