Odd Rear Vibration
Old Jun 17, 2008
yock's Avatar
yock is an unknown quantity at this point
Odd Rear Vibration
Did a quick search, couldnt find anyone else with this problem.
01 Civic ex
When driving at various speeds i seem to get this odd vibration from what I think is the rear passenger side of the car. I had the tires spin balanced and they are supposedly in perfect balance. I looked to see if any of the weights have come off but everything looks like it should be.
The only thing I noticed was this last weekend when I was adjusting my coilovers the rear passenger tire doesnt turn well. Seems to get stuck after maybe 1 rotation. Could the brakes be too tight? Would that cause a vibration?
Anyone else have this problem?
Thanks.
Old Jun 20, 2008
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Re: Odd Rear Vibration
I just had a very similar issue. It turned out to be the brake drum had warped. I assume they got real hot and I must have set my parking brake, which possibly ovalized the drums or they just got seated funny last year when I took them off to check the brake shoes. Anyways, while I was driving the brakes rubbed hard in certain spots which causes uneven wear ("cupping" as they call it). I had the tire shop balance them twice with no improvement at all. I just had to buy new tires.
Try rotating them to the front, I bet you get alot of wobble out of them at 50-60mph. Or while the car is jacked up, try spinning the wheel and watch the tire in comparison to the rim. You might notice some "hops" or low spots. I did this when I replaced my wheel bearings and there was visible wear on 2 sides. Just a few things to consider. GOOD LUCK.
Old Jun 20, 2008
yock's Avatar
Sounds pretty similar to my situation.
I'll have a shop check it out.
Feels like at 50ish they start vibrating the most. I rarely have to go above 50(mostly local driving).
Thanks for the heads up.
Old Jun 20, 2008
popee's Avatar
popee will become famous soon enough
had the same problems my rotors was warp.. had to replace them .. vibration stop..
Old Jun 21, 2008
greeen01civic4d's Avatar
could be a bad drum, bad wheel bearing, bad strut, or bad tire, even if it is in "balance"
Old Jun 22, 2008
yock's Avatar
Well I think I can rule out bad strut, mainly because I hear a slight squeek at for every rotation of the tire, even as I speed up the squeek goes faster. Also most likely not the strut because of the odd way the wheel rolls when the car is jacked up and I turn it and it stops after maybe 1 rotation.
Old Jun 23, 2008
then im gonna say wheel bearing, but when u do that, change ur wheel cylinder, shoes and drums, and get rid of all potential problems, but if its not rolling right, its either a self adjuster, bearing or wheel cylinder
Old Jul 3, 2008
yock's Avatar
k, thanks for the tips. I have all of that done then.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
OptimisticWay
Jul 10, 2015 04:31 PM
