Keyless Entry Problem.
Old Jun 6, 2008
04CivicLX's Avatar
04CivicLX is an unknown quantity at this point
Okay, just started having a problem with the keyless entry on my 01 EX auto coupe. I tried searching but found nothing.
Here's the background on my problem. When I press lock or unlock on my car the parking lights flash as they normally would, but the locks do nothing.
Ocassionally I can get the passenger door to unlock, but neither will lock. If I manually lock the doors, then the horn will beep when I press the lock button twice.
If I use the electric lock switch inside the car door, the passenger side locks and unlocks, but the drivers side does neither.
Not exactly sure what the problem is, as I can tell the remote is communicating with the car just fine, but the locks are not cooperating.
Also, I tried disconnecting the battery terminal to see if a could reset the ecu, and that did not help.
Thanks, for taking the time to read this post.
Old Jun 6, 2008
CraigW's Avatar
Re: Keyless Entry Problem.
When attempting does the drivers side make any noise ??
If you hold the lock **** can you feel anything ?
The drivers door has a switch that tells the system if it is locked or unlocked.
My 1st thoughts are drivers side actuator...The test is to briefly apply voltage to terminals and observe operation.
Old Jun 6, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
"briefly"^^
dont hold it in the open position for any length of time, its designed for a quick burst of energy to lock/unlock the door.
by holding it to long will cause it to overheat and damage the solenoid.
Old Jun 9, 2008
HLC's Avatar
HLC
HLC is an unknown quantity at this point
i had the same problem about a year ago except the passenger lock and unlock worked fine. i replaced the driver door lock actuator and good as new. i figure same solution would work for u
h4ldol
Apr 24, 2017 08:16 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
IronFist
Sep 25, 2015 07:13 PM
curaze
Sep 22, 2015 08:27 AM
