i read the timing belt and cooling system service
Old May 12, 2008
DefiantOne's Avatar
DefiantOne is an unknown quantity at this point
a trick with the cooling system with that bolt next to the oil filter, we have a trick is doing that one so you don't get too horibbly soaked, but if you have an old beach towel, wad it up and hold it against that plug while you take it out, then slide out from under the car as quick as possible. The towel will asorb most the fluid before splashing on you.
and for the crankshaft nut, just a tip, i have an ir2135 titanium impact gun i use for work. get one of those, it can break it free with over 1k ft/lbs of force lol
Old May 12, 2008
Re: i read the timing belt and cooling system service
so there is a coolant drain bolt? any pic
Old May 18, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Check my Coolant Flush DIY. Pics are there.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
