fluctuating idle
Old May 9, 2008
bigcf77's Avatar
bigcf77 is an unknown quantity at this point
fluctuating idle
so I swapped the old blown up motor out of a 2001 civic LX 1.7L with a stock used 1.7L motor that only has 30,000 miles, I hooked everything up and it runs and drives but the idle flucuates between 1000 and 2000 rpms the needle goes up and down up and down, there is no air intake but just an open throttle body but it seems weird that it would fluctuate that much even though the air intake isnt on, i have an AEM air intake on the way to my house. would an air intake stop the flucuating problem?
Old May 9, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
Re: fluctuating idle
Throttle body control problem perhaps?
Wagner
Old May 9, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
my intaked car fluctuates but not that much. its probably just amplifying the normal fluctuations due to the unlimited airflow.
Old May 9, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
first of all its not really healthy for the motor to run without filtered air...
second, this shouldn't cause fluctuating idle. If the new intake doesn't fix the problem its time to clean your icv (idle control valve). there should be diy on how to do it on this site or on honda-tech
RSKtakR
25
Sep 14, 2015 07:43 PM
pfwel1977
Sep 10, 2015 02:16 PM
Bricoleur
Sep 9, 2015 12:23 PM
msaeger
Sep 2, 2015 08:47 AM
