Distilled water instead of type 2 coolant?
Old Apr 19, 2008
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
Hi,
My coolant level is on the min mark and i can't get the recommended type 2 coolant (not even at the dealer)!
I live in a tropical country where the temperature never gets below 63F.
Will it do any harm if i top up the coolant reservoir to the max mark with distilled water, instead of topping up with honda type-2 anti-freeze coolant?
What i understood is that honda coolant contains 50% water and 50% anti-freeze. But in my country, the temperature is warm year round (never comes close to freezing). So, in my case, do i really need that honda type 2 coolant?
Old May 3, 2008
keenkreations's Avatar
keenkreations is an unknown quantity at this point
Re: Distilled water instead of type 2 coolant?
Well, from what I know, the chemical "anti-freeze" changes the property of water to also have a higher boiling point. I believe the more you dilute the coolant, the more likely it will bring the boiling point closer to that of water, which is 100 degrees Celsius.
I think your engine gets hotter than that...which means you would have the water boiling off and out of the cooling system, which would not be good.
I guess you can use it in a pinch, but you should flush out your cooling system and refill it with the 50/50 stuff asap.
According to wikipedia, it also inhibits corrosion in the cooling system itself.
Old May 4, 2008
just find a dealer with coolant, or even get some from the auto parts store. these days the coolant can mix with any other type in any car. even says on the bottle. it all has the same ingredients.
Old May 5, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
NO............only use honda type 2 blue coolant!!!! The water pump seals love this stuff.....do not put the green stuff in & do not dilute it. The coolant comes pre-mixed. You just pour it in. $20 bucks a jug though!
mattdoc
Mar 14, 2017 12:10 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
