leaky trunk (final pics p.2)
Old May 22, 2008
  #31
jimmym86's Avatar
jimmym86 is an unknown quantity at this point
Re: leaky trunk (final pics p.2)
http://www.honda-tech.com/zerothread/2189650
Last TSB is the one for leaking water...got bored halfway through this thread and stopped reading. Hope the TSB helps some others who have problems with leaking trunks!
Old Mar 2, 2009
  #32
boricuapr_1's Avatar
boricuapr_1 is an unknown quantity at this point
Re: leaky trunk (final pics at end)
Hey im glad you found the leak, mine is leaking too, i was wondering if you could take some pictures of where exactly you said that it was leaking so i can go and check it out, i will much appreciate them and good luck, Thanks
Old Mar 2, 2009
  #33
well this was my problem, you should first make sure the trunk rubber seam is not leaking where the lid meets the body. or sometimes water leaks from the taillight holes if the rubber gaskets are not put on the back. but this is where mine leaked from. that outer black molding around the rear window glass can pull out, and there are holes where the clips go into. i put rubber adhesive sealant on each clip and some around the hole and then pushed it back into place to fix the leak.
bdrickybd
Jul 25, 2015 04:35 PM
