HELP on vibrating steering wheel!!!
Old Feb 22, 2009
xDeepHole's Avatar
xDeepHole is an unknown quantity at this point
Exclamation HELP on vibrating steering wheel!!!
Hi i am new here!!
and i just got a Motegi MR12 17" installed on my 2001 civic sedan ex, with brand new 215/45/17 kumho tires and while driving on the freeway, around 55-65mph, my steering wheel is starting to vibrate... and over 70mph, vibrating gone, what could be the problem?!!
Old Feb 23, 2009
DDragon7's Avatar
Re: HELP on vibrating steering wheel!!!
Its either bad balancing or a defective tire. Did that happen before you got the new tires and rims?
Old Feb 24, 2009
xDeepHole's Avatar
it doesnt do the vibration before with stock rims, got it rebalanced earlier today, but still the same, my friend inspected it and he was saying it could be my rotors, and i was thinking about my alignment.
Old Feb 26, 2009
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
not sure if u figured out the issue but if not i might have a possible solution:
most typical aftermarket wheels dont fit snug up against the wheel hub(round ring in the middle of the rotor) and if the rim is placed on the car without a hubcentric ring the can cause vibrations and all sort of drivability issues. and a typical issue is vibrations at high speeds.
so just pull of the center cap and see if the rim is snug(doesnt move) up against the ring. if it isnt go look for a hubcentric ring. shouldnt b more than $10 if i can remember, for all 4
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
alignment NEVER causes a vibration. brake rotors can cause a pulsation wile braking, not driving. the problem is your rims or tires. if you know of a quality shop with a good balancer, you can dismount the tire and run the bare rim on the machine. this can tell yo if there is a casting problem with the rim and also check for out-of-roundness. if there is not a problem with the rims, it will be a faulty tire. try rotating front to back to see if it changes vibration. also, if this is some kind of "universal" rim, then yeah, you problem most likely is the hub rings...(or lack of)
Old Feb 27, 2009
xDeepHole's Avatar
Figured the problem, one of my front rim has a very slight bent, and the guy told me that he will fix it for 60bucks and also, he told me that i dont have any hubcentric rings on it, so thatll cause some extra vibrations. Thanks for all the help guys
Old Mar 2, 2009
Beave728's Avatar
Beave728 can only hope to improve
I'm having the exact same problem with my 2003. If you buy those rings, you should post an update whether they have deminished the vibrations or not.
Thanks!
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
