Odd problem w/heater
Old Mar 5, 2008
ElectroScantch's Avatar
ElectroScantch is an unknown quantity at this point
I have a 2001 LX 2 door, 205,000 miles, MTX. The heater refuses to blow warm at idle, but will blow warm while I am driving or accelerating. It also seems to cool down while cruising slowly. Anyone have any thoughts as to what might be causing this? Thanks.
Old Mar 7, 2008
hondarocks's Avatar
hondarocks is an unknown quantity at this point
Re: Odd problem w/heater
thermostat stuck open
Old Mar 7, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
I would try draining the radiator and the whole coolant system and them refilling it and make sure you bleed out all the air out of it. If you have an air bubble in the system you can have the needle pegged all the way to Hot turn the blower on and it will only put out cold air.
So I would try bleeding the system first if you still have a problem do what hondarocks said and replace the thermostat.
Old Mar 7, 2008
greeen01civic4d's Avatar
1. when did u change the water pump last?
2. have u checked the thermostat, likely cause
3. have u checked ur coolant level
4. i would not drain and fill the radiator, unless its due, waste of money
Old Mar 7, 2008
bomerman19's Avatar
huh waste of money? all it cost is a bottle of anti-freeze, unless your in a climate were your temps don't go below freezing and then you can get away with just water. Everyone I know that tracks there car drains and refills there coolant every spring and every fall, It's a good practice even if you don't track your car. If you can't afford a thing of coolant for $12 then I'm sorry IHMO you don't deserve to have a car.
Old Mar 7, 2008
do u realize that honda coolant is 100,000 mile??? unless it tests bad, you are wasting your money, period... btw, this is what i do for a living....
Old Mar 19, 2008
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Same problem here! No heat at idle...electroscantch, did you figure out what was causing your problem? Guess I won't be worrying about it till next year, but....
juror
Jun 9, 2015 02:15 PM
blaketippett
May 29, 2015 08:02 AM
MamaBear2015
May 27, 2015 12:04 PM
