Electrical Guru's Please Help, Dashlights Blow Fuse
Old Feb 11, 2008
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Hey everyone,
Ok, I'm at my extent on trying to fix this problem myself
My three issues:
-When you turn the headlight switch to the middle setting (for the dashlights) it blows a 15 amp fuse under the hood everytime
-Washer motor does not work
Wipers do not intermittently work in the 'low' setting, only in the 'high' setting but do not return back to the bottom of the window when you turn them off
Steps I've Taken to Check:
- When doing a visual inspection I found a bare area on both wires leading to the washer motor
-11.4 Volts go to the washer motor when you pull the wiper switch to spray mode
Now are all these circuts somehow connected to each other?
I was reading my OEM repair manual and it led me to believe that it could be the fuse panel under the dash that needs to be replaced due to the relays that it contains?
Old Feb 18, 2008
Re: Electrical Guru's Please Help, Dashlights Blow Fuse
Update:
Blown dash light fuses were caused by a short in the drivers side A pillar wiring
The washer pump was just gone
The wipers only working in HI were because the wiper motor was gone and it was getting a signal from another digital source
Old Feb 18, 2008
so you fixed it then?
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
jferristx
Jul 8, 2015 10:09 PM
ZILLA
Jul 5, 2015 05:24 PM
hmrflores
Jun 20, 2015 10:41 PM
