Indicator lights problem !?!?!?!?
Old Dec 26, 2007
civicarina's Avatar
civicarina will become famous soon enoughcivicarina will become famous soon enough
Hey guys .. just drove to a cousins place like 300 miles on christmas day. Suddenly had this weird issue that my indicators would blink just twice or once and then stop blinking.
Then sometimes they would just stop working and wouldnt work at all. Had a hard time while overtaking heavy traffic on the freeway and had to face a lot of angry highbeams from traffic behind me.
Its really annoying. They juts dont work at all .. or they would blink just one and a half time or twice and then shut off and sometimes wont even work at all.
What could be the problem and where ?
I have an 04 VP and I swapped on a EX cluster an year an a half ago and everything was perfect just till yesterday ! ... All the other stuff works perfect !!!
Old Dec 27, 2007
CraigW's Avatar
Re: Indicator lights problem !?!?!?!?
Do you mean turn signals ?? Have you tried the 4 way flashers ??
You could try a new flasher unit (plugs into under dash fuse box)
Old Dec 28, 2007
civicarina's Avatar
Yes im talking about the turn signals. Yes i have tried the hazards aka Emergency signals, and they all work fine ... Its just the turn signals !
Old Dec 28, 2007
CraigW's Avatar
If the 4 ways work then the flasher unit is most likely o.k.
Are all of the turn signal bulbs flashing when using hazards (any burned out bulbs ?)
Old Dec 30, 2007
civicarina's Avatar
yeah they are all working fine ... none of the bulbs are fused or anything !
Old Dec 30, 2007
jackscivic's Avatar
jackscivic will become famous soon enough
Is this something that happens every time you hit the multiway switch ( turn signal switch)?
start by checking fuse 5 and fuse 9 in under dash fuse box. if you still ahve your old cluster plug it in and see if anything changes. if it does then you kno the newer cluster is bad.
Old Jan 2, 2008
civicarina's Avatar
Thanks a lot guys ... the 4 way flashers are acting up too ... so i guess its the flasher unit ... thanks again ...
jimmyfloyd
May 20, 2015 07:06 PM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dooner24
Apr 14, 2015 07:51 PM
injencivic
Nov 9, 2007 02:31 PM
